Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9400PL front loading washer-control locked
My washing machine is less than 2 years old. Last week we had a power surge during a storm, then lost power. The next day I noticed the control lock light was on and the water had not drained out. I have tried all suggestions in the trouble-shooting section of the owner's manual with no luck. Also left it unplugged for a few days before plugging it back in. The control lock light is still on and it response to no amount of button pushing. What else can I try?
  • 48 Answers
I would suggest it would be better for you to bring it to repair person expert o washers. Because of the voltage fluctuation most likely they need to change some parts.
Posted on Feb 06, 2008
    Genius:
  • 3,422 Answers
the lid switch is not engaging and telling the machine that it is safe to spin/drain...check the lid switch, usually on the right had side of the top opening.....makes a soft click when the lid is closed. 2) you may have something caught in the water pump...if the washer is making all the sounds of it trying to drain, but nothing is going out, then the water pump may have something like a small sock stuck in it.
If not, you have a bad pump and it should be replaced. i think The part # is 280187 and list for $115.00 at your local appliance parts retailer.
If you want to take a chance of cleaning the pump then do the following
UNPLUG THE WASHER!
You'll need to remove the three screws that are located below the bottom front panel. (Do this easily by leaning the machine backwards toward the wall and propping the 2 front feet up with a brick or the 4" side of a 2x4) These screws are star shaped, called "Torx" screws, size #20. After you have those removed, pull the panel downward and pull out from the bottom at the same time, then set the panel aside.
Mounted to the floor of the machine near the center is the drain pump, see the hose coming out of the bottom of the tub and into the pump? That one will HAVE to be clamped off before you continue. Use 2 open end wrenches and a pair of vice grips... use the wrenches to pinch off the hose and the vice grips to clamp the TIGHTLY into place.
Now remove the drain trap cover. Rotate the hand grip counter-clockwise several turns and pull it toward you. (*THERE WILL BE SOME WATER COME OUT EVEN THOUGH YOU HAVE THE HOSE CLAMPED OFF. HAVE TOWELS READY) Use a flashlight and your fingers to inspect the pump area, remove any debris you find. Make sure it's COMPLETELY cleared out. Then re-install the drain trap cover next remove your hose clamps. Plug your machine back in and set it to "spin only" and engage. You should hear the pump fire up and water being evacuated. Is so? You did it! Rebuild everything.
Good luck,
Please don't forget to rate me as fixya..
  • Priya darshan Feb 06, 2008
    Forgot to mention this:
    To fix the lid switch:
    Remove the 2 screws that secure the console to the cabinet (on a
    Kenmore, they may be hidden under the end caps). Remove the 2 gold
    clips, and disconnect the lid switch harness. Tilt the cabinet forward,
    and off of the base. The lid switch can now be replaced
During spin cylces very load noises----bearings gone less than three old got estimate of 4-500 to fix does that sound right?
Yes, that is a good price for a main bearing repair. I wouldn't recommend it. I would buy either a whirlpool top load washer with and agitator ( we are doing to many repairs on the wp washers without agitators), or I would buy the super capacity front load duet. You will save more money in the long run with the front loader. Both of these have been the best washers built in the last 30 years. Good Luck, Appliance Specialists
Dec 15, 2010 | Kenmore Oasis 27042 Top Load Washer
Grease or rust ?? My front loading whirlpool duet washer is
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F28 error - does not drain
She is no longer having the problem - turned it on and it went through all the cycles - possibly a reset.
Thank you
Nov 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
136 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
