Question about Sony FD Trinitron KD-34XBR960 34" TV
Dark horizontal line traveling across the screen vertically
I've had my 34" HD Sony widescreen CRT for about a year and it's had this dark horizontal line that goes across the entire screen and moves slowly vertically. it takes a good 20 seconds for the line to move from the bottom to the top.
  • rcaminos Feb 06, 2008
    don't suppose there is some hidden software debugger that I could play around with?
    since I bought the TV. Foolishly I chose to ignore it since it was the last one they had and Sony discontinued the model
    Genius:
  • 3,422 Answers
A horizontal line is very common; it represents the failure of the vertical deflection amplifier and is not too expensive to repair.Repair of the unit you have is going to be around $100 -as the vertical amplifier that needs to be replaced. So u have to get it replaced by a repairman.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 06, 2008
  • Priya darshan Feb 06, 2008
    Untill n unless you get that vertical amplifier replaced ur problem cannot be solved and it is also better to get it checked and repaired by technician so that u don't have any problem in the future.Anyways u can once give a try at this method:
    Do the reset test Disconnect the power cord for 4 hours. Then when you
    power it back up
    the internal soft codes will automatically reset to factory defaults.
    if this doesn't work u have to call a technician and get it repaired..
    Goodluck once again and please don't forget to rate me as fixya..
    Guru:
  • 1,894 Answers
Ah.. frm how long do you have this problem?
  • dewan nafees ahmed Feb 06, 2008
    they dint discount the model since it was the last piece.
    they did it since was faulty piece. you can contact the DELEAR itself asking for replacement. even if he says that the warranty is over, you try to ask for it.
    Master:
    Sergeant:
  • 440 Answers
On tube tvs bestto go on main bord look for hairline craks on soldering ok redo them nice it will light up happend to mine also older model thx nick
  • nick helpap
    nick helpap Feb 06, 2008
    nope not that i know unless thers sev menu sum older tubes dont have this usally the main board craks
Dark horizontal line scrolling up from bottom of screen
if you are using a cable box .. then disconnect everything that is feeding signals into the tv ... then get a signal from some other source (like off the air antenna or video camera) ... if the tv still has the dark lines then you have a bad primary filter capacitor in its power supply .. if it works ok off the air and only does it when the cable box is hooked up .. then the cable box has an open primary filter capacitor . ... the dark horizontal bars you see is ripple from the rectified AC power that is not properly filtered ... if the TVs verticle scan rate is 60 hz and the full wave rectified AC amounts to 120 hz ripple then you will see two dark bars across the picture ... since the two signals are not syncronized then they will slip in phase with respect to each other .. thus the constantly moving pattern ..
Apr 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Aug 06, 2008 | Sony KV-27S10 27" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Top half of screen is dead
HEY WEGA-YOUR SET HAS A BAD VERTICAL OUT IC AND ANYTV GUY CAN REPAIR THAT FOR A REASONABLE (COMPARED TO REPLACEMENT OFSET) COST.JOE TV
Nov 20, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron KD-34XBR960 34" TV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
