Question about Kodak EASYSHARE Plus Series 3 Thermal Photo Printer
Hi Wizard I can't seem to get the paper to work on the printer. How do you add paper into the printer, i've never used this printer before, i tried working it for about 1 hr last night. but it keeps saying, out of paper..add paper and press print. Where do you put the paper!?!?! please help
  • 1 more comment
  • fiddleminger Feb 10, 2008
    thats the thing.... i dont have the manuel....
  • tiggerbud Apr 05, 2008
    My printer will not feed the paper or it will go in the front and come out the back without printing. I put in new paper and new color cartridge.
  • astros Apr 14, 2008
    THE PAPER WILL NOT FEED INTO MY PRINTER DOCK I DONT HAVE THE # TO THE PRINTER DOCK BUT BY CAMERA IS A KODAL EASY SHARWC643
    Genius:
  • 3,587 Answers
Where to put the paper? There's a manual that comes with this printer, that clearly shows how to open this up, and add paper. I'd recommend you review that first. You may be thrilled when you find it
Posted on Feb 06, 2008
My canon copier D420 had a paper jam. can't get the copier to work now.
Try checking the paper path, there might be a broken or loose gear in there, a bent wire or stuck debris. If you done this and all seems ok but the error message keeps flashing, try to do a hard reset. That usually clears off error messages. If nothing happens, you might need to call a technician.
Feb 07, 2013 | Canon New Usa Imageclass D420 Laser...
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
Out of the blue my printer stopped working. I've checked drivers. Not sure what else to do
Hi
1. Check first the USB cable connection by unplug and plugging it back the USB cable connections and then check the printer icon if it says READY.
2. Check for the printer driver that might be corrupted. Adding again the printer using the add printer wizard will install new printer for your computer. If still the same, try to uninstall and reinstall the printer driver and then re add again the printer and if it prints the test page, then it solves your problem.
3. Check the print spooler service if it locks up. Try this link to restart the print spooler. http://www.fixya.com/support/r8758623-check_fix_print_spooler_service_causes.
Regards
Jun 29, 2011 | Dell 3100cn Laser Printer
My HP C2780 Won'y print paper size 5.5" X 4.25"
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Select replace current drivers
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish.
Click on start then search type notepad.
Write any stuff and then try to print.
Oct 31, 2010 | HP Photosmart C7280 Printer
I put the paper in the rear tray as instructed to do but it will not print.the paper pulls to the left or the right and that is all that happens.i read the book and everything but i get nothing.
first of all, make sure the type of paper you are using is compatible with your printer. Try different types.
Then make sure you have:
the printer as the default printer
the paper orientation to portrait
the paper type to Auto Select
the tray selection to Automatically Select
If these didn't work, write to me how you added the printer to your computer, ie. Add a Printer wizard manually or automatically plug n play
Dec 02, 2008 | Office Equipment & Supplies
D-LINK DP301U
TCP/IP printing for windows xp:
you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
Step 2 Select Local Printer and click Next.
Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
Step 5 Enter the IP address of the print server and the port name and click Next.
Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
Step 7 Click Finish to close the port configuration wizard.
Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
May 29, 2008 | D-Link DP 301U (DP-301U) Print Server
"Out of Paper" problem
i,d suggest the paper sensor that you,ve disabled is suspect.
Alternatively, could be a cabling error.
Try a new printer cable, if this fails uninstall remove completely all software and printer, along with cabling. start computer/shutdown. re setup the whole printer as a new installation. if non of this works. Bin it and buy a new printer.
Finally if you,ve got standard windows 98. upgrade to 98se. might help.
Mike @ Compurepair.
Feb 23, 2008 | Computers & Internet
Paper isnt loading correctly
My printer does that too, after many copies have been printed out. There is this mechanism that pushes the paper forward and another to slide one paper in... well it won't get in. I tried to add "grease" at the right side, "facing the printer", of that mechanism that made contact to the rollers which slides a paper in..  well my printer now works fine
Mar 19, 2007 | Canon Pixma MP450 All-In-One InkJet...
Kodak EASYSHARE Plus Series 3 Thermal Photo Printer Logo
124 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
