Question about Philips 60PP9352 60" Rear Projection Television
CONVERGENCE I have an Philips 60 Inch rear project tv where the IC's seemed to have gone out as the screen bows and you can not get the convergence to set with the remote. How do you put the TV in service mode to determine if I can set the convergence there. If I can't is the IC"s the problem? how much problem are they to replace. Do you have
  • 113 Answers
Your Ics are bad and you prob have a resistor or two that have gone out too. If you are good with a soldering iron and have an hour to give up you can fix it. They are at location 7044 and 7045 on your board. They are STK 392-120's and the part number is 932212344682 good luck with you repair.
Posted on Feb 06, 2008
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Philips 60 inch projection hdtv
O K, the misalignment is usually caused by a failure in the convergence output circuit. If the customer convergence alignment is no help then the outputs ic's are suspect.
Jan 03, 2009 | Philips Magnavox 9P6034C 60" Rear...
Convergence problem with Philips 60PP9352
Screen looks 3D
Solution:
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
Screen looks 3D
Solution:
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 60PP9202 60 in.
sound like your convergence amps are blown. also known as stk's
Dec 19, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
