Question about LG DLE9577 Electric Dryer
LG DLE 9577
Dryer was installed and cord added. We have power to the unit because the screens light up. You can select dry cycles but when you press start, the button blinks and nothing happens. LED screen also begins blinking.
  • mattdono Mar 24, 2008
    I am having the same problem.....sometimes when I turn it on all the lights come on and the screen reads 18:FO whatdoes this mean?
  • 489 Answers
Check to make sure that the power legs are correctly installed.  Use an volt meter and measure voltage across neutral and hot.  Hot leads should be on the left and right side and neutral is in the middle.  Hot to neutral should be 120v.  Hot to hot should read 240v.
Posted on Apr 28, 2008
Frigidaire affinity dryer code ad
Hey Cindy, thanks for your submission!
I see that your Frigidaire dryer is displaying an error code of "ad". The "ad" error code will display with the "Auto Dry" cycle has been selected. If you did not select the auto dry cycle I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord for at least ten minutes. Once power has been restored to the dryer and if the error code is still persistent you may need to have a replacement control panel or wiring harness installed. I would recommend having electrical parts replaced by a professional technician this will prevent any personal injury. Best of luck! -Matt
Mar 08, 2016 | Frigidaire Dryers
I have a Maytag Epic z, electric. They dryer turns on but not heat
Instructions
Dryer
Examine the household fuses or circuit breakers if the unit is not working, as the Epic z dryer uses more than one circuit or fuse. Replace or reset as necessary. Use a power outlet with 240 volts or more, which you can determine with a volt meter.
Close the Epic z door firmly and press the "Power" button for at least one second if the dryer has power but isn't working. If there is no heat, verify that you selected a heat dry option.
Look inside the dryer for objects that may have fallen out of pockets if there is a clicking or thumping noise. Examine the drum edges and remove items if possible. Separate pieces of clothing inside the dryer if the items got tangled together, and reduce the load size if necessary.
Tighten the legs on the dryer if the unit is rocking side to side during use. All four legs should touch the floor evenly. Adjust as needed.
5
Press and hold "Start" if a "PF" (power failure) error code appears. If the code persists, press "Power" and then a new cycle selection.
6
Contact Maytag for help if an error code with an "E" and a number appears on the display.
Washer
7
Ensure the Epic z washing machine is plugged into a grounded three-prong outlet if it doesn't start. Shut the lid firmly and press a wash cycle before selecting "Start." Select "Start/Pause" if an error code appears on the display and unplug the unit for several minutes. Reconnect power and choose a new cycle before pressing "Start."
8
Verify that the hose connections are tight on both ends and only high-efficiency (HE) detergent is being used if the washer is leaking. Do not open the washer lid during the wash cycle, as water can deflect off items and splash out of the washing machine.
9
Select "Rinse and Drain/Spin" if the door does not unlock. This removes any excess water from the washer tub. If "Add a Garment" is illuminated, select "Start/Pause" to unlock the door.
10
Verify that you placed the correct detergent in the correct dispenser if the dispenser is clogged or is not dispensing as expected. Wipe out the dispenser drawer with a damp cloth and dry it before adding the correct detergent.
11
Leave the door open after use (if small children and/or pets are not present) if the washer smells badly. Place a laundry cleaning tablet, available at grocery and hardware stores, into the washer and set the washer to the highest temperature wash possible to clean the unit.
Both Units
12
Set a piece of 3/4-inch plywood under the washer or dryer (or both if stacked) if the machine is thumping or vibrating or the floor seems too weak to support the unit(s).
13
Tighten the feet on the unit and make sure all four feet are level on the ground if there is vibrating or thumping during use.
14
Do not connect the washer or dryer to an extension cord, as extension cords cannot supply the power necessary for the unit(s).
Jan 09, 2013 | Dryers
Frigidaire electric dryer error code AD
Hello - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Jan 07, 2013 | Frigidaire AEQ6000ES Electric Dryer
No heat
Hello Patty Hanna - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Oct 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My LG DLE 5932w CONTROL PANEL WON'T LIGHT UP AND THE DRYER ONLY BLOWS COLD AIR. COULT THIS BE A BAD FUSE?
Check the 220 volt circuit breaker or cycle it. If on the other hand you have fuses instead of breaker panel, with 220 volt you should have two fuses to contend with and one or both may be blown.
Nov 18, 2011 | LG Dryers
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer not heating
Answer Did you select an Air Only cycle or Air Only temperature option?
The Air Only cycle or Air Only temperature does not add heat to the dryer. Expect loads dried with the Air Only cycle or Air Only temperature to take longer to dry. Air Only cycle or Air Only temperature can be found on the control knob or button with the other temperature selections.
Has a household fuse blown or has a circuit breaker tripped?
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuses or reset the circuit breakers. If the problem continues, call an electrician.
Did you recently install a power supply cord on the dryer?
The power supply cord may be incorrectly installed. Review the Installation Instructions to make sure that the power supply cord is properly installed.
Dec 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool dryer LEC9000PW0 will not turn on
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG NEPTUNE GAS DRYER
Unplug the unit and take off the cover where the cord goes in. You may have one burnt wire under that cover.
Mar 06, 2008 | Maytag Neptune MDG5500AW Gas Dryer
LG DLE9577 Electric Dryer Logo
148 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
