Hello. My Linksys network card for my laptop does not seem to be working properly on encrypted networks. I Have the Linksys WPC54G. It will connect to the network, but after 10-20 minutes, it will disconnect. About every 3-5 times it disconnect, it resets all of the network settings for the secured network (like network type, network key, etc.). Any ideas on how to fix this?
Comments:
Feb 08, 2008
- The provided software is running in the background, otherwise Windows won't connect to anything. However, if I try to connect to a network USING the provided software, it doesn't connect to anything either. I have to have the software running, but use the Windows XP UI to connect to it.
Feb 10, 2008
- I am, however the provided software does not soly work. It must be running in the background for my computer to connect, however, I can't connect to the network that way. I have to connect through the Windows XP wireless connector, with the provided software running in the background. I havn't had this problem before. It just started randomly doing this. However, it only does this to Wireless networks.
I used to have a Linksys WPC54G. Thia is normal for the LinkSys WPC54G. How ever in your configurations make sure everything is enabled. But as this being a wireless adapter you should make sure you use AdHoc Mode configurations and set it to channel 6 works the best and set it to G-Only mode not mixed..See the network light blinks and it should be flashing fast for it to conect. I had this same problem. I decided to reconfigure my Linksys to AdHoc and it seemed to work better form me. For as the secure links I set them at non secure and I manually set up my IP Address which is 192.168.1.01-255 Sub net mask is 255.255.255.0 Default Gateway is 192.168.1.1 DCHP Server is also 192.168.1.1 I do hope this helps if it doesn't I say try moving your laptop around until your Wireless Network enables. there is always Tech Support on Linksys.com also. Good luck and I hope this works for you.
both power and link led lights blink simultaneously on wpc54g. what does this mean? having...
(More)
both power and link led lights blink simultaneously on wpc54g. what does this mean? having installation issues with this product. Trying to install to a compaq presario 700. I've installed the cd that comes with the product but it stops when it tells me to connect the adapter. Adapter's led lights blink simultaneously. Computer does not recognize the hardware. I connected the adapter to a different laptop and both light went solid at once and the add hardware screen popped on. help with this matter. thanks!
Wireless says I?m connected I can see the network connection. It is excellent. Power lights are on...
(More)
Wireless says I?m connected I can see the network connection. It is excellent. Power lights are on the card its self but I cannot get to the internet. The laptop is showing two Local area connections one is disabled. I tried each of them separately. Not sure if the drivers need updating on the card. Any help would be appreciated
Laptop freezes when wireless-G card version 2 is inserted with the version 3.1 installed. What...
(More)
Laptop freezes when wireless-G card version 2 is inserted with the version 3.1 installed. What should I do?
Hi, My service tag number is: B5M3T1S. Also, when I ordered this laptop, I had a special wireless...
(More)
Hi, My service tag number is: B5M3T1S. Also, when I ordered this laptop, I had a special wireless adapter put into it and it is an....Intel(R) Wireless WiFi Link 4965AGN.Thanks for all your help!
