Question about Altec Lansing VS2121 Computer Speakers
Altec Lansing VS2121 speakers ticking
The speakers produce an intermittent ticking sound when on, with no signal input. The ticking continues for about ten seconds after I turn the speakers off.
I have the same speakers and the same issue, I'm still not sure what causes it but I found that when you move the wires around on the right speaker it goes away ...just can't make it go away permanently. They aren't that expensive so replacing them is a valid option.
Posted on Nov 13, 2009
    An expert who has answered 500 questions.
  • 620 Answers
Hello there
First things first
1) check cable for bad connectivity or dust. clean .
2) your board or volume control may be damage, or dust inside clean carefully ( if you can) with air spray for computers.
3) I hate to tell, .....change your speakers, may be is bad IC on board for speakers.
good luck
Posted on Feb 08, 2008
Sound breaks. have to fiddle with volume button
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Jun 27, 2011 | Altec Lansing VS2121 Computer Speakers
I need to figure out how to open up the subwoofer for the Altec Lansing vs2121 model. Thank you
theres no on/off button for the subwoofer. once you plugged in the power cable,turn on the speaker system by turning the VOLUME knob on the right satellite until you hear a click sound.
An LED will light on the front of the right satellite when the power is ON. if you still dont hear any sound from the sub woofer then check to make sure that all cables are connected properly and are making a clear connection.
hope this help
Sep 06, 2010 | Altec Lansing VS2121 Computer Speakers
It seems as if everything is connected correctly, but I get no sound from my Altec Lansing speakers. What can I do?
buy your self a external sound card dude, the one on your laptop or pc is prob dead. problem solved..
Jul 27, 2010 | Altec Lansing VS2121 Computer Speakers
Altec lansing vs2121 model speakers blown
I have the speakers ( in perfect condition) but can not find the base unit. Do you want to sell your base unit ? Or do you want to buy the speakers ?
Mar 11, 2010 | Altec Lansing VS2121 Computer Speakers
I have no audio device can not turn speakers on
Good day heigei, hi if you turn on the speakers but no ON lights came on, the problem is your Speakers' power supply stage, either a fuse opens (most likely) or something got burnt from the plug to the transformer, then to the rectifier diodes (got shorted then fuse opens) or to the regulator section. check also the power switch for poor contacts, of course you may need to open the speakers, If by any chance you hear something like hum.... check for open signal wire, check the IC amplifier also, a bad IC amplifier produce no sound or produce a loud humming/cracking sound. If you have no idea of what im talking about, have it checked by a technician. thats it.
Jan 20, 2010 | Altec Lansing VS2121 Computer Speakers
Continuous noise from speakers, not subwoofer
las cornetas se escuchas muy bajos, porq no tengo los drives instalados
Mar 16, 2009 | Altec Lansing VS2121 Computer Speakers
Altec Lansing VS2121 not working
its best way to check the problem whether hardware is not working or any driver related in computer,
1) hook up any working head phone in your pc's head phone jack (generally of green color plug)
2) checkout that both LH and RH side speakers working!!
after that we can guess.
Dec 18, 2008 | Altec Lansing VS2121 Computer Speakers
Looking at the manual page 3 of the pdf says Connect the lime green 3.5mm stereo cable (hardwired into the right satellite) to the lime green input labeled ?FRONT? on your sound card. So your right speaker should have a cable with a green end that plugs into your standard audio out jack If you have multiple outputs and don't know which you are set up for, then turn the speakers on and up, put a long song on, and plug that green wire into every jack on the PC! If you've got no other issues you'll hear something! Good Luck
Aug 28, 2007 | Altec Lansing VS2121 Computer Speakers
My Altec Lansing Speakers aren't working
Try rolling back soundcard drivers. I had the same problem when Win XP updated my soundcard drivers.
Jan 16, 2007 | Altec Lansing VS2121 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
264 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
