Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Reset for new lamp
After installing new lamp, when the set was turned on the rest message did not appear as manual suggests. Everything work fine...but how do I reset when the reset message does not appear? Thanks for answers...
  • ebehlke1 Feb 07, 2008
    To: CTF1800...nice try, but to no avail. I removed cartridge once with tv unplugged. Then again while plugged in...no reset message on start up. Should I wait until I get "change lamp signal", then retry? OR? Is there any way to find reset signal in menu items? thanks.
    President:
  • 4,402 Answers
Take the lap back out and put back in
After replacing the lamp cartridge, when you power on the TV, the message "Did you change the lamp? Press ENTER for Yes, press CANCEL for No"will appear, press ENTER to reset.
Posted on Feb 06, 2008
  • Cary Farah
    Cary Farah Feb 07, 2008
    YES!
  • Cary Farah
    please mark the post as fixya!
Manual or diagram for 2005 Escalade 5th wheel by k-z rv. Replaced gfi for outlets in the tongue, fixed that issue, but now slides on the floor don't work.
If one GFI is tripped (No working) then I agree nothing will work;
Check to be sure the GFI is Active by plugging a lamp into it.
If the lamp doesn't work then do 1 - 4 repeat.
1) Press rest
2) Check with Lamp
3) Replace GFI
4) Check with Lamp
Note:
No need to install a GFI on everything, The one GFI is most likely wired to trip for all 120v circuits.
Mar 26, 2018 | RVs
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
I have the same problem. I replaced the lamp and starter with new . But after I press the button reset the mesage replace the lamp continue to show it and the blue light is missing (INSIDE THE BOX)with any...
It may be that the bulb and starter are not inserted correctly. The message indicates that something is not making contact. Make sure they are seated properly and firmly. They need to be twisted, like installing a fluorescent light bulb.
If the bulb begins functioning, but you are still seeing the message, push the reset button, then turn the machine off for a minute or two. If everything is installed correctly, the light should work, and the message should be removed.
Jan 14, 2011 | Ecoquest Fresh Air Air Purifier
A message appears when the set (LCD) is turned on whichstates that the lamp should be replaced but it is workning. Replaced the lamp 11 months ago and it has a 1 year warranty. What is the purpose of the...
that lamp timers are only there to give you an idea that the lamp may fail soon. the tv will count to a certain number of hours and then give the message on screen. most tvs the number will be around 4000hours or so. i suggest using the tv until the lamp fails you may change a lamp that has many many many more hours when you dont need to. there is a timer that you can reset if you consult your owners manual so the message will not show up any longer.
Dec 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Need instructions for lamp unit part number TY-LA2004
the projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
Jan 28, 2009 | Office Equipment & Supplies
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Hitachi CPS860 LCD Projector
Turn On. Press RESET switch for 3 or more seconds until a lamp and 2000 message appears in the middle of the bottom of the screen. Press RESET again and this message will expand to include cant remember then press arrows left arrow and the 2000 will reset to 0. If the first press does not immediately provide a message press it for longer and expect to see message on release. As mentioned you have to be quick otherwise the menu dissapears. If this happens just do it again until you get it completed.
Thanks to the previous reply.
This works it has just been done on a CPX960 without bulb replacement. SO
Dont replace the fuckin thing till it needs to be replaced.
Jan 18, 2008 | Hitachi CP860960LAMP Projector Lamp for...
Resetting lamp panasonic PT40LC12
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Jan 06, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
554 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
