Question about SanDisk Sansa e250 MP3 Player
My screen comes on but cannot see the display folders and or music.
  • solo20002 Feb 08, 2008
    Thanks. After trying your soulution i found out my wife had dropped the device and when i opened it, a loose part was the problem., Thanks for the input.
  • 758 Answers
I would recommend you to get a firmware upgrade for your device..to get the firmware upgrade go to the sandisk site...
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Hope this helps
Please rate accordingly
Thank you
Computerrep
Posted on Feb 06, 2008
  • Jean Sintulaire Feb 08, 2008
    Thanks for the reply...
I turn my player on and hit folder to open up my songs and nothing is coming up it just goes back to folder it was working a few hours ago i finished listening to a song then it stopped working i thin
You'll need to check that the files in the folder are MP3 or WMA (Windows Media files). Unfortunately, no other file types are supported so you will need to avoid iTunes and use Windows Media Player or similar to manage your library and the Eclipse.
Oct 21, 2012 | Eclipse CLD2 MP3 Player
How do I take music from the mp3 player on to my pc?
Plug it into a USB port on your computer. If it doesn't open on the screen, click Start, click Computer and locate your devise on the list of drives and discs, right click on the devise name then left click Open on the drop-down menu. The device files should display. You can then drag and drop any music files to any folder on your PC, normally your Music or My Music folder.
Jul 29, 2011 | Coby MP300 MP3 Player
Olympus ds 40 can't display recorded voice folders on pc
There are a total of eight folders in the recorder that are in a tree format. Under the “Root” folder
are “Folder A” through “Folder E”, “Audible” and “Music” folders, and recorded or transferred
Language and music data from a computer can be saved as “files”. “Folder A” through “Folder E”
are voice-recording folders, so choose one of these five folders when recording on this recorder.
Up to 200 files can be saved in each folder, and up to two layers can be created within the “Music” folders.
Feb 14, 2010 | Olympus DS-40 Digital Voice Recorder
How to download music to my philips 8GB mp3 player
Try going to my computer and then opening one of the removable drives. There should be a "music" folder in there and you can just drag and drop your music onto it. If this doesn't work you should be able to use Windows Medis Player to sync the music to your mp3 player.
Aug 01, 2009 | Philips GOGEAR SA6045 MP3 Player
I deleted the music folder and nt able to play the songs in mp3
When I had the same accident this is what worked for me. I disconnected my sandisk player from my computer. After waiting until the sandisk software completed it's termination programming, I re-connected it to the computer.
Because I use Microsoft Windows XP, a window pops up asking if I want to open the device in Windows Explorer. Answering "yes" and then selecting the "Folders" from the tabs at the top of the window will display the sandisk along the left column as "Sansa e250". By double clicking on the folder labeled "PPI NAND" a drop down list of subdirectory folders should be displayed. If the folder "MUSIC" is not there, you will need to create a new folder and label it "MUSIC".
Here is how to create a new folder.
With the folder "PPI NAND" highlighted, move the cursor up to the upper right hand corner of the "Windows Explorer" window and select the tab "File". From the drop down menu select " New Folder ". This should cause a folder to appear in the window to the right of the "Sansa e250" window. The new folder should be highlighted and labeled "New Folder". Select the "New Folder" and rename it "MUSIC". When renamed, select the PPI NAND folder and the new folder "Music" should be listed as one of the folder in the subdirectory. If so, you can select it to see if the Music folder contains and music files. If not, you will need to copy or drag your files into the new "MUSIC' folder.
Once I did all of this and disconnected my sandisk player, the player and let the software complete the programming work before shutting it off, it worked fine. My original problem was caused by shutting my sandisk player off after disconnecting it from the computer before the sandisk software completed its work.
Hope this helps.
Mar 12, 2009 | SanDisk Sansa m230 MP3 Player
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Missing MUSIC folder...
  1. hhuhihhygdydcxdsdfgyffxdfgtbgnhucdhyfgufrvcftygfcrvf
May 04, 2008 | SanDisk Sansa e250 MP3 Player
I cant figure this out
it is like as crash of psp system, If this is the first time you've used the Memory Stick Duo, you must format it with psp to create the proper PSP folder structure. Copy the music/audio files from your computer into the MUSIC folder inside the PSP folder on your Memory,
You can save and play music/audio on your PSP system in the following file formats:
MP3, MP4, ATRAC3plus, WAV, WMA. press triangle for Display or hide the control panel. you can visit http://www.us.playstation.com/Support/PSP/Music/s_psp_mu_CF.html for more helps. hope this helps.
Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
SanDisk Sansa e250 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
