Question about Philips Magnavox 27MS343S 27" TV
Magnavox 27mdtr10s I have white horizontal lines on the top of the tv. It started out as one or two and is now about 4 inches worth. Would it be economical to have it repaired
  • 113 Answers
Its really a toss up. I have tried to replace alot caps on that board and could never find the source of the problem. Every one I get now I have resulted to replaing the board. The good news is that the board is less than 100 dolllars from the right repair shop if you can do it yourself. Other wisw you are looking at 100-150 part plus 150 labor and thus it would be uneconomical.
Posted on Feb 06, 2008
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
1995 Magnavox tv (model TS2560) Horizontal control WACKY
No, it is most certainly not worth fixing. In fact, it is worth nothing - even if it were working great. Probable cause: an obsolete electrical component. Cost: no TV tech will touch it. Sorry. Suck it up and buy yourself a moderately priced TV.
Jul 28, 2017 | Philips Televison & Video
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
No picture on magnavox 32MT6015D
THAT THIN WHITE LINE IS YOUR HORIZONTAL LINE MEANING YOU ONLY HAVE THAT. THE GOO NEWS IS YOU HAVE HIGH VOLTAGE MEANING YOU ONLY NEED VERTICAL TO FIX IT.. I WOULD REPLACE THE VERTICAL TRANSISTOR OR CHECK FOR ANY BURNED RESISTORS ON THE VERTICAL SIDE
Feb 22, 2009 | Philips Magnavox 32MT6015D TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
White horizontal lines at top of picture
Yes, definitely worth fixing. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor (no more than USD4.00 in price) usually gets it working perfectly again. If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 17, 2008 | Toshiba MD24FP1 24 in. TV/DVD Combo
Philips Magnavox 27MS343S 27" TV Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
