You can find these instructions on page 140 of the User's Guide. The English User's Guide is here: http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
If you have Caller ID, you can block faxes sent from specific numbers and/or all faxes which do not include a Caller ID number.
To turn on the Block List feature:
- From the control panel, press up arrow or down arrow repeatedly until Fax is highlighted.
- Press select (checkmark).
- Press up arrow or down arrow repeatedly until the Fax Setup submenu is highlighted.
- Press up arrow or down arrow repeatedly until the Fax Blocking submenu is highlighted.
- Press up arrow or down arrow repeatedly until you reach the Block List menu item.
- Press left arrow or right arrow repeatedly until On appears.
- Press left curved arrow to save and exit.
To add each fax number you want to block:
- Press up arrow or down arrow repeatedly until you reach Blocked Fax Add Entry.
- Use the keypad numbers to enter the name of the person associated with the fax number in the Name field.
- Press down arrow once.
- Use the keypad numbers to enter the fax number in the Fax Number field.
To block faxes sent from an unidentified number (a number with no Caller ID):
- Press up arrow or down arrow repeatedly until you reach the Block No-ID menu item.
- Press up left arrow or right arrow repeatedly until On appears.
