Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore Elite Dishwasher will not start
I have a Kenmore Elite 665.13785k602 dishwasher that will not start. The main power source is fine. When the main fuse is turned on a faint click-click can be heard, but the control panel on the front door does not light up, and touching the panel to start the machine does nothing.
  • Marcucci Feb 06, 2008
    Are these fuses inexpensive and/or easy to fix. How do I locate/isolate the blown fuse?
    Genius:
  • 1,226 Answers
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Posted on Feb 06, 2008
  • Emelio Navaja
    Emelio Navaja Feb 06, 2008
    You should open and trace the board from the power plug onto circuit board panel. If you can find any cylinder material (some is glass with aluminum both end). It easy to identify the blown fuses because the wire is visible and it is open when busted.
    However; if find nothing in the series of examine maybe the washer is lock. Please repair to the manual for the unlock instruction.
3 Suggested Answers
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite 665-16959000 dishwasher - soap door
It appears your dispenser wax switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
How do I fix a flashing Start/Resume light on a Kenmore Elite dishwasher model 665.13793K601?
These dishwashers are known to accumulate moisture in the keypad and then short. The solution that I have seen is to replace the keypad...It is possible that all of your issues with this dishwasher could point back to the keypad. After spending $$$ on the circuit boards, do you want to throw and additional $135 for a keypad? or replace the whole unit? Food for thought. Here is a link for you:
http://www.repairclinic.com/PartDetail/Control-Panel/8572855/1180767?modelNumber=665.13793K601?RCAID=1000065
May 22, 2014 | Kenmore Dishwashers
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
My kenmore Elite stopped working after my daughter open the door during a cycle. There seems to be no power. Circuit breaker is fine. Any thoughts? Thanks
Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
Mar 28, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher won't start until running until at
The 2 minutes is most likely the "Fill" time in the cycle therefore since the water supply is active the fill solenoid is spent or not getting a signal.
Dec 12, 2009 | Kenmore Dishwashers
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Jul 31, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite Dishwasher 13863 will not start
I would check the door interlock, an electrical switch that prevents the dishwasher from running whenever the door is open. Maybe a loose wire there.
Feb 25, 2007 | Kenmore 13863 Stainless Steel Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
922 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
