Question about Marantz PMD660 Digital Voice Recorder
Marantz PMD660 Headphone Jack inside machine
The headphone jack fell back into the case, and I can't seem to get the front of the recorder to come off. Removed screws and volume fader knobs.
Too much plastic!
  • haack Feb 06, 2008
    Unfortunately you have broken the jack off the internal PC board. This is not an easy fix. Contact
    George Myer TV & Stereo (310) 820-1113
    Attn: Morris
    12418 Santa Monica Blvd
    Los Angeles, CA 90025 USA
I poted step-by-step instructions here for fixing PMD660 headphone issues. Check it out.
Posted on May 31, 2008
There's also a section of double sided tape along the back that kept me going for a bit. Once removed the back lifts off a little easier.
Posted on Apr 28, 2008
Take out the pins that resemble watch pins! remove the stickey label with the
power switch,usb and 5 volt jack cut outs! If you have taken out the screws needed up to this point and you are a little bit technical this should get you into the unit.
If you don't have the skill, hire it out. Joe Taken
Posted on Mar 13, 2008
How do I link external speakers to Grundig 32VLC6110C
the headphone output will be on the under ridge of the lcd at the front dont see it being at the back
looking at your TV's spec it says its got a jack
so youll need to hunt for it
seems it has 1 scart 2 hdmi and headphone jack
Dec 09, 2014 | Computers & Internet
Connecting headphone system to a dvd recorder
does dvd record have head phoen jack out if not use rca outs in back rca to sterio mini jack to headphone wirless base ok
Jan 11, 2008 | Radio Communications
Marantz sr3053 stuck in headphone mode
Usually the headphone jack is like a mechanical switch and it's probably just not making a good connection inside. Use the correct size headphone jack and insert it then remove it maybe a couple of times and see if that fixes it.
Apr 18, 2014 | Marantz SR8001
Headphone jack driver
There is no driver for the analog output. Make sure you have selected the computer internal speakers and the headphone jack will take that output. A more likely cause for your issue is the contacts inside the jack are sprung and are not making contact. If that is the case then the jack needs to be replaced.
Mar 10, 2014 | Acer Computers & Internet
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Apr 22, 2009 | E-Machines T2898 (764296109563) PC Desktop
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
Amilo Pro V2035 - Broken Headphone Jack Stuck inside Headphone socket
Also remove the battery and any other removeable plates below the notebook to check for additional screws. Check if there are any rubberized "feet" or plugs covering access to still more screws. Keep screws and their locations organized in case they are different length.
Aug 12, 2008 | Fujitsu AMILO Pro V1000 Notebook
Headphone socket detached from casing.
I was having the same problem, but finally got it to crack open gracefully. There are quite a few screws, maybe about 7 of them. Once you get all of them out (including that one beneath the battery), pry open from XLR side. It should go up a good few degrees. From there, it should just come apart.
The headphone jack is a few layers in and you'll have to undo cables and one ***** towards the front, but on the inside. It holds the push tab to eject card.
Jan 16, 2008 | Marantz PMD660 Digital Voice Recorder
Headphone jack not working.
If you have a headphone jack at the front and the back, it may be a wire to the front panel is not connected properly on the Motherboard.
Aug 03, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Marantz PMD660 Digital Voice Recorder Logo
240 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
