Question about Gateway FPD2275W LCD Monitor
Out of range
Try to power up and screen says out of range
  • Kevin Thurman
    Kevin Thurman Feb 06, 2008
    Excellent, thanks for the help, works great now. You the MAN!
Hi my monitor is on and i can see everything on my screen . however ther is a rectangle box that is diplaying "out of range" i do not know how to make the box dissappear
Posted on May 12, 2008
    Brigadier General:
  • 6,966 Answers
If there is no hardware issue, this message indicates that your PC's Screen resolution settings (and/or Refresh Rate) are above the capability of the monitor. This can be corrected by booting into Safe Mode (F8) and lowering as necessary.
Good luck and kind regards.
Posted on Feb 05, 2008
  • Louie  Role
    Louie Role Feb 06, 2008
    Hi again,
    Congratulations and am glad to be of assistance. I would appreciate if
    perhaps you can change the rating now to "FIXYA" as your concern has
    been settled.
    Cheers.
Out of range
replace vga screen cable could be faulty or screen could have blown a power source.they blow if the power that they use gets a surge,can be repaired.
Jan 04, 2014 | Computers & Internet
All Screen elements lit
Remove power from board by unplugging the wire harnesses and replacing than again. See what happens.
Sounds like the board is locked out some how..possibly there was a power surge/failure during your absence.
Can only guess at this time.
Oct 19, 2013 | GE JSP34 Electric Kitchen Range
I have a Kenmore Ceran electric slide in range, model # 629.46799895 ...it was on, started beeping, and showing fault code F1 on the screen
Sorry to read about your problem.
Try this to determine which part is needed.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
I tried to help you.Please help ma and rate/vote this responce. Thanks and good luck
Jan 04, 2011 | Kenmore Kitchen Ranges
Screen is not working. clock is flashing with PF
This is a power failure code.Cheeck the main power supply and make sure the circuit breaker is ok then you should be able to press the clear off key and see if the unit will reset.
Jan 01, 2011 | Kitchen Ranges
EO F2 is displayed on the display. Tried pushing the off button to cancel but this did not work Whirlpool Model # WEP 84801
hello,
what this mean is an indication of an error sensing showing that there is an over flow of liquid substance(water) on the panel or screen of the washer.
what you need to do to fix up this problem is to unscrew (open)the range then trace the wire down to the panel then clean up all forms of dirt,liquid ,or water around the panel and the screen do this with care to avoid more damages on the range please make sure that all form of power supply are disconnected from the range before working on it.
thank you and thanks for using fixya.
Jun 15, 2010 | Kitchen Ranges
Out of range
may ber it is screen resolution issue.
When you power up the computer press F8 key then enter in enable vga mode.
Then change screen resolution to 1024*768 then apply AND ok.
Jun 26, 2009 | Westinghouse L1975NW Monitor
Gas range shut off with PF on screen what does
The PF means there was a power failure, you should be able to clear this code by pressing the cancel button
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My whirpool electric board is not working
try pause/cancel first then if no help try resetting clock then pause/cancel
Dec 30, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
KitchenAid convection oven - panel went black during self-clean SOS
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
Nov 22, 2007 | KitchenAid KGRA806PSS Gas Kitchen Range
Gateway FPD2275W LCD Monitor Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
