Question about Dryers
Dryer lights are on but dryer does not work
  • ruthstead Feb 06, 2008
    It is my daughter's dryer as well...lol
    She said they have those old fuse panel and they changed the fuse twice, Does that mean they only changed one and there is another one???
  • ruthstead Feb 08, 2008
    Thank you sooo much. I will mention that and see if it helps
  • 552 Answers
I had a question recently from my daughter and her husband about their dryer that was doing the same thing. Dryers are usually 240v and they are connected to a double circuit breaker or two 120v legs of some kind and a white neutral wire. Dryers will have lights and indicators working if one side of the double circuit breaker trips, and if it happens to be that hot leg that tripped.
First go and reset the circuit breaker or replace the appropriate fuse(s). It should work fine.
Posted on Feb 05, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 07, 2008
    Yes,
    The dryer is 240v. This means that there are two fuses.
    You may have to pull out the cartridge fuses if you have them.
    If you don't know how to check them, just try one you know is good.
    If someone can take the cover off safely from the electric panel where the fuses are, then you may be able to tell which are the wires that come from the dryer.
    Be extremely careful! safety first!
    when replacing fuses in those panels , it is a good idea to stand on a rubber mat(car mat ,door mat etc.) and wear some sort of gloves(rubber prefered). Just remember if the gloves are not for electrical work, they may not protect you as well, but they would be better than nothing on your hands.
    Also, these fuses to the dryer should be 40 amp and at the very least 30 amp rated. If not they may blow too quikly.
    In most electric panels that have screw in fuses that you have to replace when they blow, you will most likely find the tubular cartridge fuses that I mentioned in this email.
    If not you may need to get an electrician or someone qualified to replace the electric panel.
LG 2301 dryer will not turn on but door light works
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2010 | Dryers
HOW DO I LIGHT THE PILOT LIGHT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 15, 2010 | Estate TGDS740JQ Gas Dryer
Dryer control board does not work. no lights nothing, but the dryer inside light works.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have no power dryer interior light works but nothing on panel?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
The dryer drum does not rotate. The dryer
heatman101
Jul 16, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
''clean lint filter'' light is on- dryer will not work
is the door trigger working properly if its faulty then the dryer will not work
Jun 05, 2009 | Dryers
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
Marvin
Marvin
