Question about Xerox DocuColor 12 Printer
Dc 12 hi i am having trouble when i print rrom my fiery i am getting lines running thru the prin they get bigger then smaller but it doesent do it when i scan a picture please help
Error code is 14 376 plese solve the problem
Posted on Feb 12, 2008
  • svsr Feb 12, 2008
    error code is 14 376 plese solve the problem
Fiery driver bizhub c450
Changed the media type? Try different thick paper? Try printing directly to the copier instead thru the Fiery
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 30, 2013 | Minolta Office Equipment & Supplies
Dc 12
Did you check the sensors?
Feb 28, 2008 | Xerox DocuColor 12 Printer
I have got a Xerox Docucolor 12 printer, a Fiery X12, and a laptop running on Vista. I dont have any cables except the power cables and was looking for a list of everything I'd need to get it running...
There are 2 cables that go between the fiery and the printer, not sure where you can get these.
You will need to be running windows xp
connect to the fiery with an ethernet line
download the drivers, command workstation, and fiery remote scan from the xerox website
hopefully the fiery still has its software loaded otherwise post a request for a copy here.
Nov 11, 2010 | Xerox DocuColor 12 Printer
UN WANTED LINE APPERS ON PRINTED PAGE WHEN PAGE
I do not know what kind of copier you have but lines (when you run thru the feeder) are usually caused by something on the glass under the feeder. If you open the top, you should see the big piece of glass and also a piece about an inch or two wide next to the big one. Look closely at the smaller glass for any spots on it. A spot will show up as a line on the copy. You can use windex to clean it.
Mar 18, 2010 | Office Equipment & Supplies
Canon IR C-4580 with Fiery controller
No, but the fiery will just speed up your prints etc.. I have the c3380 and c5185, they are stand alone with no fiery. If you are buying this machine for office coping it will be fine. But remember! this is a Buisness Color machine. In my customer base the 80's have done well as long as you run them as an color machine and not the office black and white work hourse. The color prints are great without any help from fiery. Sales people will try to sell you all!!!!
Jan 06, 2010 | Canon ImageRUNNER 1670F Copier
Konica Minolta bizhub 6500 pro/Fiery controller scanning problem
Hello a Fiery print controller is basically a computer, which needs to be rebooted once a week to get rid of temp. files. Try shutting down each fiery every Friday and restarting Monday morning and your problems will be resolved. What model Fiery's do you have (IC-408, IC-901),? let me know which model and I can see if their is a patch to correct this issue. dave.herron@att.net PS: I am full line KonicaMinolta dealer
Nov 24, 2009 | Konica Minolta Office Equipment & Supplies
Canon ir C3200 Print Resolution
Print out a Fiery config page ....there may be something in the fiery settings on the actual Fiery box, you'd have to reboot and run setup when it prompts you.
Jul 12, 2009 | Canon Office Equipment & Supplies
EPSON LQ 1150 Roman letter two last two Can not print in foxpro
best way to come out of this problem is to fire your printing using an batch file
ex.
set print to scrn.txt
set prin on
? 'hello'
? 'welcome to fast printing'
set prin off
set prin to
run fastprin
create fastprin.bat file
edit fastprin.bat
@echo off
type scrn.txt >PRN
then execute the above program
Mar 04, 2009 | Epson LQ1170 Matrix Printer
Docucolor 12 Not Printing with another Fiery
could be a few things, the ips pwb in the machine might be faulty, which can cause these types of issues, a driver issue woth the video boards on the fiery, or other pwbs on the machine itself. You would have to run the machine for a while on another fiery to make sure no other faults occur before condemning the machine or the fiery
Jan 17, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
