Question about One For All URC4220 Remote Control
Need help? When I push the TV button or the set button or anything, It will not blink but comes on steadily for about 30 seconds. All the instructions say press the set button and wait for the red light to blink. It will not blink, it just comes on steady. I am at a loss for what to do!! I also need help programming the remote to a sanyo tv?
  • 2 more comments
  • grneyedgrl83 Feb 12, 2008
    i need the codes for urc3220 for my sanyo tv
  • Anonymous Feb 12, 2008
    I hit tv button and set button and nothing happens. The remote is urc3220 and I have No info on how to program it to an Emerson TV
    I have a One for All Remote urc3220, and have no instruction for it. I would like to use it for an Emerson TV, for which I don't have a remote. I have tried pushing TV button and Set button to get to a programing, but nothing happens. I think i have a code for the TV (1047?) but I'm not sure it's correct. Please help
  • MIZTEA
    MIZTEA Feb 22, 2008
    I NEED HELP WITH THE URC-4220 ONEFORALL REMOTE MY TV IS A ILO MODEL NUMBER IWF2706 I NEED THE CODE!!!!
    Problem Solver:
  • 5 Answers
Grneyedgr183
here is the code for your remote TV Sanyo
all for one
remote cod 0154 0159 press tv hold set down till light blinks 2 timen then inter code light s will flash 2 moor times your done
Posted on Mar 29, 2008
Repair tv
You didn't say anything about the model or make but a lot of times this comes from bad capacitors...try this...on the open fins on the back of the TV, try putting a blow comb on there and set it on low and leave it there for about 3 minutes, turn the set on and see if it comes right on, if it does there are bad caps on the power board, it could be replaced or you could repair it yourself for a couple dollars
Dec 17, 2017 | Zenith R56W36 56" Rear Projection...
How to set garage door opener
Find where the antenna comes out of the garage door opener motor and look for either a learn button or a set of switches. (You may need to remove the lens cover from the motor head). If the antenna is not found, look for a wall-mounted external receiver with antenna. It should also have a removable cover.
To program using the learn function, push the learn button on the garage door opener motor. An indicator light should turn on and glow steadily. You now have 30 seconds.
Press and hold the corresponding learn button on the remote. Stop once the motor light blinks instead of remaining solid.
To program a switch-type opener, again take the cover off of the motor unit or wall mounted receiver (wherever the antenna is located). You should see either 8, 9, or even 12 switches that may have two or three positions each.
Open the battery cover on your remote to locate the remote switches. For every switch on the motor, set the remote switch to the exact same position. Open = Off / Closed = On. This is where the pen or small screwdriver may come in handy for moving the switches.
Close the battery cover and test the opener. If all switches match, it should work immediately.
I hope this helps.
Good luck.
Nov 10, 2010 | 2008 Toyota Avalon
TV will not turn on. Push power button green
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If it is 2,2 I have START TO FINISH STEP BY STEP INSTRUCTIONS AND PHOTOS TO SHOW YOU WHERE THE FUSES & PROTECT RESISTORS FOR THEM ARE LOCATED.
The instructions tell you everything you will need for the repair and how to do it.
You can buy all the parts needed for less than 30 dollars on Ebay (I know the best seller there) I have repaired hundreds of these sets with this problem
If this information has helped you rate this solution as I do this here for free.
If you want the instructions & photos let me know and I will post them here for free.
SD TECH
Dec 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Reprogram keypad remote
Setting the code:
1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal indentification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Apr 25, 2009 | Computers & Internet
Sears keyless pad
hello - we have a craftsman model 139.53684 and these are the instructions for setting the personal entry code - (you will need two people doing this) To set the code using the Premium control console: 1 Enter a four digit personal ID # of your choice on the keypad then press and hold ENTER. 2 While holding the ENTER button, press and hold the LIGHT button on the premium control console (the premium control console is the main opener button mounted in the garage probably near your door) 3 Continue holding the ENTER and LIGHT buttons while you press the pushbar on the premium control console (now all theses buttons are held) 4 When the motor units lights blink Release buttons - it has learned the new code. If bulbs are not installed you will hear two clicks. To set the code using the 'LEARN' button (you will need a ladder & two people doing this) you used the learn button to set the new remote. 1 press and release the learn button on the motor. The learn indicator light will glow steadily for 30 seconds 2 within 30 seconds enter a four digit personal ID number of your choice ob the keypad then press and hold the ENTER button 3 Release the button when the motor unit lights blink If bulbs are not installed you will hear two clicks. I hope this fixes your problem - please post & let me know - thanks Sam
Apr 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
Mar 27, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Blinking light mitsu ws-55515 rptv
if the set is shutting down it should blink a code. Try pushing in the menu and input buttons on the set both at the same time and hold them in for 8 seconds to see if the self diagnosis will falsh a two digit code. Let me know what happens
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Led light will not light
dvd citizen i need a code please
Jan 08, 2008 | One For All URC4220 Remote Control
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
One For All URC4220 Remote Control Logo
50 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
