I constatntly get a popup that says I unplugged an audio device (speakers)from RealTeck Audio Manager. This started happening about 2 months after I first built this machine. I even installed the latest available drivers for Vista. I get nothing from the vendor in the way of help, just try an empty drive with clean install of OS. These people do not even know their product. Any one have some hands on experience with GA-EP45-UD3P issues?
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume iconsystem select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer or if it
you might have to uninstall then reinstall either the driver or the sound devices control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustmentsthere or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver hope this helps
better search for the driver for the hardware you install for sound there are different drive as you mention that you have win XP so search for the driver accrording to the operating system you are using see for both hardware as well software issue for more problem do consult you nearest autorised service centre for help or do visit the microsoft web site for more help so untill then see you sir hope you will find the solution for your problem
For the first problem open your multimedia properties box under the audio tab you will have a sound recording device specified, check whether you have your device listed, usually you have your say ( Realtek HD Audio input or the respective company input device who supplied your audio drivers). If its not listed ten you might be having problem with the drivers or hardware you will have to call the service engineer to have to problem solved.
for the second one try the same solution. select the proper devices under the audio tab in multimedia settings.
