Question about ATI ALL-IN-WONDER X600 PRO, (256 MB) Graphic Card
"No Signal" problem while playing games
Hey there, I'm having problems playing games with a recently (newly) installed ATI graphics card. Here is some information about my current adapter:
Adapter Type: ATI Radeon HD 2600 Pro
Chip Type: ATI Radeon Graphics Processor (0x9589)
Memory Size: 512 MB
I run on a Intel() Inside motherboard and the computer is kind of old (about 3 years or so) and I had decided to upgrade it recently. I installed several hardware such as a bigger HD (250 gigs to be exact), a bigger power supply (550W) than the previous 300W, and I also bought an extra Memory Chip (512 MB) which brings me to a total of 1024 MB of memory.
The problem here, as I see some other people have, is that all the games I try to play end up with the same result. Which happens to be the "No Signal" message which appears on my monitor shortly after I start a game, see screen tearing, endure the painful "screen freeze" and then a short blink of orange or yellow on the screen.
The first time I had trouble with this graphics card was the day I had brought it back from the workshop. It worked fine for about an hour or so but then I saw screen tearing and it eventually got worse from there. I would get a blue screen saying a "Ati2dvag driver" was the cause of the error. Later on through the month, It had stopped showing the error, but continued to have problems (the "No Signal" message). I also tried reinstalling drives, downgrading to (some) lower drives (wasn't sure of which specific drive, but was sure it fixed ati2dvag problem) and reinstalling Windows (XP Home Edition) without any positive result.
The only upgrades the workshop had done for me were the installation of the graphics card and the installation of the HD (which were not simultaneous). The HD was installed about a month after the graphics card. So basically, I had to install the power supply and the memory chips myself (which worked fine). I am currently using an Intel(R) Pentium(R) 4 CPU 2.93GHz processor and a Intel Desktop Board. The ATI card I use has a DVI connection (I use a VGA to DVI connector for my monitor).
Only games found on the web (such as flash/java/etc) are playable for me right now.. all other highly or mildly graphical games do not work. Before I had updated my system with the ATI graphics card, all the games I had worked pretty normal with the exception of lag and so forth.
The workshop had came up with several solutions such as cleaning out my computer (both physically and virtually) which I had done and that did not solve the problem. They had also recommended upgrading my drive and getting extra memory which I had done, having little to no new or unexpected results (after 1 hour, game play was impossible).
Here are the games I have tried without success;
-Supreme Commander
-Battlefield 2142
-Archlord
-Dark Messiah of Might and Magic
-World of Warcraft
-Warcraft 3
Problems also occur while I watch High-Definition videos as the screen turns an inverted color scheme and is slowed down, possibly lagging.
I would appreciate some help :)
  • 1 more comment
  • Toyoka Feb 05, 2008
    I don't really have the time (or money) to change my graphics card to a better one (already wasted too much money upgrading), though I know its is one of the only solutions. If there are any other alternative solutions, I am willing to try them out.
  • Toyoka Feb 06, 2008
    Thanks aceltix , Il try you solution and see if it works :) Thank you for your input.
  • dnavarre Nov 06, 2008
    I have the same problem. While playing games and, depending on their graphics, they last various times.
    ==Failed games==
    Warcraft 3 (about an hour)
    Archlord (20 minutes)
    Overlord (30 minutes on low graphics)
    Fable (ten minutes)
    Battlefield 2141 (2 minutes)
    Black and White 2 (5 minutes)
    ==games that work==
    Half life 2 (and episodes 1 and 2)
    Portal
    Team Fortress 2
    Halo
    The Movies
    Quake 4
    While playing the "failed" games, after their time, my screen goes black, the current sound loops over forever, and a yellow block with "no signal" appears for a few seconds. Then I have to reboot. I don't know anything about my computer because I got it from my uncle.
    Scholar:
  • 119 Answers
Hello to you.look..here is a quite sad solution.
I have many computers in my home and one of them has a MSI ati radeon 9550 td/256 ddr2 on it,a mainboard via kt 400 from MSI and an old athlon xp 2400++,1 gmemory.
I ask you to belive me that on this old computer I played and still play all the games on the market.for instance the super graphic game stalker.
ok..from my experience I tell you...your board supports fine almost every new game now on stores.
the problem you have unfortunatelly is a phisical problem.
your video card has ,as you told me,lack of signal and strange behaviour.
first of all,try this.
take a new ati catalist from ati/amd site or from www.guru3d.com.
if with this up to date driver it doesnt work...well...try also to make a 3d mark test to see how its going..
if you fail this test wellagain..
well if you discover that the software problem is out of discussion..
the board is damaged in this case,which means the rams from it ,in the most of the cases are damaged..It can be a factory mistacke,by puting there rams with differnt latencyes..they work for a while and bang...fail...thats why the old drivers work fine ..they dont need the same resources like new ones.
In this case I suggest you to bring it back and ask for a replacement..
good luck
bye bye
Posted on Feb 06, 2008
    Master:
    Sergeant:
  • 440 Answers
Cuse x600 cant take that man to slow ok u need least x1900 on games uw ann do ok best bet
Posted on Feb 05, 2008
  • 1 more comment
  • nick helpap
    nick helpap Feb 05, 2008
    turn down game son meduim ok x600 is slow man rated 2 outta 10
  • nick helpap
    nick helpap Feb 06, 2008
    cant push a x600 not even halo 1 look good ok slow
  • nick helpap
Graphics card upgrade on Acer Extensa 5230E-901G16Mn laptop
Unfortunately, laptops are generally locked down in terms of graphics cards. The GPU is integrated into the laptop mainboard due to space constraints.
Your only option if tied down to a laptop for any reason would be to purchase a more recent laptop with a specific graphics card in it.
Any discrete (NVIDIA or ATI) graphics card that was manufactured after 2008 should be sufficient to run most games.
If you're looking to play games on more intense graphic settings, your best bet would be to look for laptops with the NVIDIA GeForce 9600M/240M or better, or the ATI Mobility Radeon 4600/5400 or better. Either brand with at least 512 MB of video RAM will work well.
Mar 21, 2010 | Acer Computers & Internet
Computer Keeps RESTARTING when ATI video driver installed
weve got the same prob.i also try what you did on your pc..but nothing happen but when i put a new graphic card it fix everything..try this..buy a new graphic card,
Dec 13, 2009 | ATI RADEON Graphic Card
Ati 2600 pcie graphics card problem playing battlefield2
it's not the graphics card or the game would come up with different colours and flicker, try to re-install the game
Sep 02, 2009 | ATI RADEON HD 2400 PRO Graphic Card
My HIS Radeon x1650XT hangs after playing 3D Games.
change your graphics card or you may upgrade your card.
Jun 03, 2009 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Computer restarts on game start
Remove all traces of ATI drivers from add/remove programs and reboot before trying to install the newest Catalyst Control Center. The latest - 9.4 - does NOT have your card listed (they list the PCIe version, not AGP).
Recently ATI removed support for many of their "legacy" cards. 9.3 may be of more use to you.
Apr 13, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Cannot play FIFA09
Uh oh. It looks like you're out of luck.
FIFA 09 PC Requirement (minimum):
Graphics: 6600 Nvidia graphics card or ATI equivalent with support for Pixel Shader 3
DirectX Version: DirectX 9.0c"
Nvidia 6600 came out at 2004 and it supports DirectX 9.0C (Shader 3 came with 9.0C)
ATI Radeon 9200 came out at 2003 and only support DirectX 8.1 (which support shader 1.2 - 1.4)
Nope, Radeon 9200 will not support Shader 3 (neither will it support 2.0).
Time for a new video card maybe?
I hope this answers your question.
Mar 16, 2009 | ATI RADEON 9200SE Graphic Card
ATI Graphics error
Looks like you've got a virus while playing, though that only would happen if your running an illegal copy of the game.
Otherwise while the game hanged, and you inevitably rebooted, the card drivers were damaged and erased from the hard drive. You might be now in low resolution standard VGA that's activated by windows when the drivers fail.
You should be able to still access internet explorer to browse the internet, from there you'll need to go to www.ati.com to download the most recent drivers for your card and reinstall them.
Oct 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Ati x2300 update
search on the net for your graphic card drivers for XP NOT vista
Jul 02, 2008 | ATI Computers & Internet
Graphics Card
My bad, i was going to just ask about your PSU and went on trying to fix your problem :) If you do download rivatuner, check how hot your graphics card is running in graphics intensive games (it has a chart recorder). BTW I have a 1600XT and speeding up the fan helped a lot!
A.J.
Jan 23, 2008 | ATI RADEON X1650 Graphic Card
ATI ALL-IN-WONDER X600 PRO, (256 MB) Graphic Card Logo
855 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
