Sony DAV-S300 System Logo
Anonymous Posted on Jan 08, 2010
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
  • 1 more comment
  • Anonymous Jan 08, 2010
    The I-HD901 didn't come with a DVD player.
    I realize this is very easy for you but, it isn't for me. I'm confused about the dvd player. Is this step optional or does the system have to be hooked up to a dvd? This particular tv I'm trying to set the system up to does not have a dvd hooked up to it. Please advise.
  • trevor hewitt Jul 15, 2012
    i am trying to hook up m i-hd901 but it dident come with a dvd player or anything its just the speakers how do u hook it up plz help me
Marvin
Level 3:
Top Expert:
  • Sony Master 85,242 Answers
  • Posted on Jan 08, 2010
Marvin
Sony Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29051153
Points
266281
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Testimonial: "I am very sorry! The info u gave me was VERY helpful. It took a lot of stress off me. You are very knowledgeable and I app. the time you spent with me"
  • 2 more comments
  • Marvin
    Marvin Jan 08, 2010
    sorry, typo
  • Marvin
    Marvin Jan 08, 2010
    call me at 925-577-7157
  • Marvin
    Marvin Jan 08, 2010
    there is no way to sort this out without knowing all the inputs and outputs on this product and yes i know it doesn't have a DVD player, but there are inputs on the IHD901 for audio and video. This is not easy for , I am trying to get information here so i can help u, this is why i asked for a call, something I very seldom offer as an option. I am in the USA
  • Marvin
    Marvin Jan 08, 2010
    I spent time with u on the phone fell the rating is unfair could u please change it to a helpful? thenks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 29, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
6497
Points
You posted this in the wrong section. You don't have a Sony dav-s300.
This is for the iCinema i-HD901. This has no video input. You need a surround receiver. Get a 5.1 surround sound reciever, then you plug the video/audio into the reciever, then plug the video output of the reciever into your tv, then there should be 6 outputs for your speakers to connect.Here is are some helpful links.http://icinemasurround.com/PDF/iHD-901-Specification.pdf
http://icinemasurround.com/site/ihd-901/
  • Anonymous Apr 29, 2012
    I should add, this is only a 5.1 speaker system. Not a home theater system that includes a dvd player, etc... With this speaker system, you also need a surround receiver plus a dvd/bluray player of your choice.
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
Need to know how to hook tv up to prewired home surround system. connections on wall, seakers inceiling
Run the audio output from the tv rca audio output, to any input of receiver and hook your speakers to receiver. You cannot hook up speakers to tv cause its a low level audio output. Needs to be amplified.
I don't know how to hook up my i cinema i-hd901 i don't have the amplifier and don't have a flat tv could you help me please!!!!!!!!!!!!!
I bought a cinema HD 901 home theater system. How would I hook that up? Do I need to buy a 5.1 receiver? Because there's no power supply on subwoofer how many watts do I need on my 5.1 receiver if I have to buy one
5helpful
1helpful
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
2answers
We have a Sony Trinitron and a Sony STR-K670P. We use to have it hooked up to a DVR, but now we went down to basic cable. I can't seem to get sound to come through my surround system. Any advise out there?...
if your trying to use the dvr still your probably not connecting it all properly. make sure that. having a sony trinitron you have alot of connections on the back. if you connect all of the accessories that you have on your tv directly into each input and use the tvs main output connection to connect straight to your surround sound. this should fix your problem. plus you wont have a bunch of stuff hooked up to your surround sound receiver
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
5helpful
2answers
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
1helpful
2answers
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
