Question about Nintendo Wii Console
Wii remote i press any button on my wii remote and the lights beep on and off and no controlers work...
  • 2 more comments
  • johnny1984 Feb 08, 2008
    I have two wii remotes and I can get neither remote to work not even to turn the console on. 1 remote just two lights flash and go off and the other all 4 lights flash and do the same
  • Anonymous Aug 24, 2008
    lights flash on - off on remote and nothing works
  • Anonymous Dec 28, 2008
    All 3 Remotes, 4 lights blink, then go off, no connectivity, Problem still here..
  • Edwin_Reyes Feb 02, 2009
    One of the remote when i press any button blink 2 light and not work and the other blink all 4 light andoesnt work, and i try to syncronize pressing red buttons in the console and the remotes a lot of times and recplace the batteries too
    President:
  • 4,402 Answers
Resync, red button under the front door and under the remote battery cover.
Posted on Feb 07, 2008
My remotes were synced to another wii how do I re-sync them?
Step by step instructions on how to sync the Wii Remote or Wii Remote Plus to the Wii console using Standard Mode.
Note:
Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
What to Do:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. If you are using a Wii mini, the sync button is located left hand side next to the battery compartment. The sync button is a darker shade of red than the console.
  3. Remove the battery cover on the back of the Wii Remote to be synced.
    • Some models of the Wii Remote include a hole in the battery cover and a tool on the wrist strap to push the SYNC Button with. With this model, the battery cover does not need to be removed to access the SYNC button.
  4. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  6. This sync procedure must be followed for each additional Wii Remote added to the system.
May 19, 2014 | Nintendo Wii Console
Tip
How to snychronize a Wii Remote to the Wii console
A lot of people have trouble synchronizing their Wii Remotes to their Wii console. I have written a short tutorial on how to do this.<br /><br />Figure out which scenario is similar to yours and proceed with the solution-<br /><br />1) When you turn on the Wii console and press any button on the remote no lights light up at all. This is because the remote is dead, you must replace the batteries in the battery compartment on the underside of the remote. If the controller is using a charge pack you need to put the controller on its charger.<br /><br />2) When you turn on the Wii console and press a button on the controller all four lights blink a couple times then turn off. This means the controller is not synchronized. If your controller has ever been previously synchronized all you need to do is press the 1 and 2 buttons at the same time and it will sync up.<br /><br />3) If option 2 doesn't work then this means you are preforming a first time synchronization with the remote. While the Wii console is turned on you should open the little compartment that is just below the disc tray. Then you should press the little red button. After pressing the red button you should open your Wii Remotes battery compartment, remove the batteries and press a similar little red button inside of the compartment. Put the batteries back into the controller and the controller should be synchronized! <br /><br />If none of these solutions are working then the problem is a technical issue with either the Wii remote or the Wii system, you should contact technical support for more information.<br /><br />I hope this helped with the synchronization of Wii Remotes!<br />
on May 16, 2011 | Nintendo Wiimote & Nunchuk Controller...
Tip
Syncing your Wii-mote to your Nintendo Wii
So you just bought a new Nintendo Wii Remote Controller but when you click the power button the four blue lights at the bottom just blink huh? Well that just means your Remote needs to be synchronized to your Wii.
Here are simple step by step instructions to do so.
1) Turn on your Nintendo Wii.
2) Open the door on the front of your Wii covering the SD card slot and the SYNC button.
3) Open the battery compartment on the back of your Wii-Remote Controller.
4) Press the red SYNC button on your Wii.
5) Press the little red SYNC button on your Wii-Mote.
6) Wait until a solid blue LED light comes on on one of the four lights at the bottom.
7) If it doesn't work the first time, try again.
Your Wii-Mote should now be synchronized.
on Dec 21, 2009 | Nintendo Wii Remote Controller
I have 3 wii remotes was using one that had batteries it died so i replaced all remotes with new batteries and now none of them will sync or work they just turn off right away
After replacing the batteries, you may have to do a hard sync by pressing the sync button beside the SD slot on the Wii and the sync button on the back of the Wiimote underneath the battery cover. Both buttons are a kind of dark reddish-brown colour.
Mar 25, 2011 | Nintendo Wii Console
We can't get two player mode to work in Wii Star Wars. We press the + on the 2nd controller and the player will not drop in. The blue lights show the controller is working. Why is this not working?
Press the home button, select Wii Remote settings, select reconnect, and press the 1 & 2 buttons at the same time on the Wii Remotes you want to connect. - I just did this and it worked a treat.
Feb 01, 2011 | LucasArts Entertainment Company LEGO Star...
My Wii remote blinks blue lights but it won't work with the Wii
Try to resync it. Press the red button behind the SD cover on the front of the Wii and then press the red button behind the battery cover of the remote.
If this doesn't work and other remotes don't work also, the bluetooth module in your Wii is probably faulty. You can replace this yourself (no soldering required) or have this done professionally.
Jun 15, 2010 | Nintendo Wii Remote Controller
Help
go to the Wii home, press the Sync button and hold it, without letting go press the Sync button on the Wii control blue lights on the remote should start blinking let go of both Sync buttons and there, your Wii Remote Controller should be now working,
Apr 10, 2010 | Nintendo Wii Console
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
Remotes don't seem to register with gaming system
Before Pressing the Red Button inside the Battery Compartment. Make sure to open the Small "Door" on the Front of the Wii and press the Small Red "Sync" Button first and then Press the Small Red Button inside the Battery Compartment. You should hear a "beep" to confirm that your Wii Remote has been reconnected.
I hope this helps. Take care =)
Dec 08, 2008 | Nintendo Wii Console
Cant add a controller
I had the same problem and called Nintendo support. They had us unplug the wii console for 30 seconds, plug it back in and start the system back up. BEFORE pressing the A button on the health and safety screen, we needed to take the battery cover off of one remote, press the red sync button, then quickly press the sync button on the front of the wii console (in the front - you have to open the flap). Once the single blue light was on at the bottom of the remote, do the same with the other remote (press the sync button on it and then on the wii console). Then the second blue light should be lit on the second remote. Hope that helps!
Nov 29, 2008 | Nintendo Mario Kart (Wii) for Wii
Nintendo Wii Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
