Question about Sony STR-DE915
Auto - protect message
I have a sony receiver it reads a message auto protect there is no sound how do i remove this message so it will work
  • dawnabela Feb 06, 2008
    the auto-prtect was something that always would appear whebn you frist turned on the unit. it was a matter hitting to buttons a the same time to fix it but i cant remember what they were. this unit is from 1999. so its an older unit but i only used it 4 times or so i know its not an internal problem
  • 317 Answers
There are two small transistors in side of the receiver, that are not working, if you are daring enough, go ahead and try to find out which ones they are, or find a repair tech that is willing to do it, as this requires surgical soldering skills to fix.
Posted on Feb 05, 2008
Sony STR DE835 receiver - no sound from speakers and headphone jack
The problem is in the audio output semiconductors, they have shorted causing the fuses to blow and it is in auto protect mode to prevent further damage. I recommend a professional to assess.
Mar 10, 2012 | Sony STR-DE835 Receiver
When i turn up volume on receiver it display protected and then i loose sound on my sony str-d865 receiver
That's a protection circuit in the output of the speakers. It indicates a short, or abnormally low resistance of the speaker itself. Disconnect the speaker wires from the unit, and see if the message goes away. If it did, you have a problem with your wiring, or the speaker itself.
Mar 13, 2010 | Sony Audio Players & Recorders
It senses an error or problem and shuts down. Try disconnecting all the cables and wires attached to it. Try it again. If it still shows protect message, it is an internal fault and requires a repair shop. If it clears up, then the problem may be a shorted speaker wire. Correct the short when reconnecting the speakers.
Mar 08, 2010 | Sony STR-DE545 Receiver
My sony receiver will turn on but not work
This "protection" mechanism is causing your speakers to go silent. Check the back of your receiver for loose/disconnected or shorted wires. Your receiver may have a TEST button that will tell you whether there's a problem with your connections.
After having checked/reconnected all speaker wires, run the test by pressing the button. Sound will come from each of the speakers, usually clockwise and go round all speakers until you press the button again.
Should there be a problem, the display will tell you whether the polarity is wrong, there's no connection, etc. If the messages don't make sense to you, go to your user's manual for an explanation.
Sep 07, 2009 | Audio Players & Recorders
STR-DE197 Continuous Auto-Protect
Probably dry joint on an output/regulator chip or a failed output ic.
Jun 29, 2017 | Sony STR-DE197 Receiver
Flashing message on my reciever
PROTECT, PROTECTOR or the letter P is flashing in the display of the A/V receiver. Solution
sp.gif sp.gif Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: Ifthe receiver is played back at maximum volume level it may enter theprotect mode. Maximum volume listening will cause the receiver to runvery hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Somereceivers provide compatibility with the higher sampling frequenciesthrough alternate connections. Consult the owners manual for specificinformation.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 15, 2008 | Sony STR-DE545 Receiver
Getting a "Protect" message in the display which then shuts down
The speaker wires were al little frayed, so I cut and stripped new 3/8" leads and when re-inserted the receiver worked fine. The problem was a short from the frayed wires touching either the back of the receiver or some other metal near the terminal.
Dec 06, 2008 | Sony STR-DE185 Receiver
my sony receiver has a message auto protect so i get no sound how do i remove the message and get sound
Jan 19, 2008 | Sony STR-DE915
Not powering on
remove all external devices and speakers
the clicking is the auto protection.
Dec 08, 2007 | Sony STR-DA9000ES Receiver
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
223 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
