Question about D-Link DE 805TP (DE-805TP)5x10 Mbps Networking Hub
Problems connecting two computer together
I am trying to connect to computers to the internet using the DE-805 TP one computer is using XP and the other Vista my system is showing connected at 10mbps but it keeps giving an invalid IP address so I am unable to connect to the internet. Please help me.
  • Anonymous Feb 13, 2008
    need IP address to connect
  • 118 Answers
Can you post your ip addresses here
Posted on Feb 06, 2008
Tp link TL-WR740N router indicating orange light what to do?
Means no internet connection , better check the network connectivity properly.
Jul 15, 2016 | TP-LINK TL-WR740N Router
When I go to use a TP - LINK High gain Wi-Fi USB adapter, my internet access always seems to be blocked and I get a yellow triangle with a black exclamation mark.
Your wifi router should automatically assign an IP address to your adapter. If it doesn't, you may need to turn "DHCP" on in it, or manually assign an IP address. If you need to assign, you will need to see the address of a working system, and use something similar.
Nov 01, 2014 | TP-LINK Tp link Tl wn822n 300mbps High...
How to setup tp-link TL-MR3220 on xp2002?
Connect the router's WAN port to your cable-modem.
Connect the computer to one of the LAN ports.
No other "setup" is needed.
Apr 29, 2014 | D-Link AirPlus DI-524 Wireless Router
I USE MIFI TP-LINK MODEM M5250..THE PROBLEM IS WHEN USE MY COMPUTER TO CONNECT TO MIFI WIFI SIGNAL ITS DOESNT HAVE ANY PROBLEM...BUT THE PROBLEM IS WHEN I TRIED TO CONNECT USING HANDSET THE WI-FI SIGNAL...
If you don't have access to the settings the handset is using to select the security protocol, or know what they are, the issue is probably with the protocol the handset is using to connect to the wifi, Check the computer that can connect, to see which protocol it's using. Then, I'd try a support ticket with the manufacturer of the handset to see if the issue is resolvable. It really depends on how flexible the handset protocols are...None, WEP, WPA2-PSK (TKIP), WPA2-PSK (AES), and WPA2-PSK (TKIP/AES) are all different options. Choose the wrong protocol, and you can't connect.
Jul 02, 2017 | TP-LINK Computers & Internet
How to convert a tata photon in to a wifi connection
First, you need an internet gateway. Do you have already some kind of internet connection through DSL, CABLE Modem, etc? The TP wifi will first have to be connected to your network (wired LAN). Then, once that is done, you need a computer with web browser to access and configure the setting in the TP. There is a CD that comes with the TP. It contains "Easy Setup Assistant" program to configure your TP wifi.
Feb 15, 2013 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
I have Windows 7 64-bit Home Premium on a Gateway desktop computer. I plugged in the newly purchased TL-WN722N wireless adapter and installed the driver from the CD. I connected to the Linksys WRT54G...
Dear ubose1, This is Howard from TP-LINK Support Force. Maybe the anti-virus software blocks the driver installation. Please disable the self-defense function and exit it. Then try to install the driver again.
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Sep 18, 2011 | TP-LINK TL-WN722N Wireless USB Adapter...
Hello, I have been having problems with my TP-LINK TL-WN353GD 802.11g/b Wireless Adapter on my PC, which is running windows xp. Unfortunately I am getting extremely low internet speeds with it (download...
Try disabling Windows power control over the wireless adapter. you can do this from control panel > network adapters > double-click the wireless adapter > "Power management" tab > un-check the "Allow the computer to turn off this device to save power"
I hope this helps
Jun 07, 2011 | Computers & Internet
Internet problem: I have configured my new TP LINK WA500G as an Access Point with DHCP enabled, connected to a router with fixed IP. All the tested devices (android tablet, WM phone, W7 and W XP...
please note that if your router DHCP is open you must close the access point DHCP if the twoic is open DHCP make a conflict and internet is stoped
best regards
Apr 21, 2011 | TP-LINK TL-WA500G 54Mbps Wireless Access...
Cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Jan 31, 2010 | Computers & Internet
I have a toshiba laptop, already have existing computer all set up but having trouple conncted laptop to wireless. Have adsl modem and tp link router. tp link is asking or network key to be able to...
Your wireless network is secured and thats why its asking for the network key. If you dont remember the same, contact your router manufacturer or ISP and get the router reconfigured
Jul 03, 2009 | Computers & Internet
D-Link DE 805TP (DE-805TP)5x10 Mbps Networking Hub Logo
289 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
