Question about Magix ENTERTAINMENT Music Studio 10 deLuxe ( Windows ) (26758)
Multi track recording
When I try to record a second track, the sound from the 1st track automatically is registered on the second and so on. Third track has 1st and 2nd behind. Doesn't matter if I'm running a direct line or not. I've tried everything I can think of to get this to stop but with out luck.
Any ideas?
  • acousticdave Feb 06, 2008
    Thanks... didn't work.
    Maybe you don't understand... I record track 1 no problem. When I'm trying to lay down track 2, track one automatically records on track two along with what I'm trying to put on 2 by its self, so I've got BOTH tracks on 2 now. Then when I try to lay down track 3, I get a mix of track 1 (which is a single instrument), track 2, (which is a mix of track one plus what I recorded on track 2 and what I've just tried to record on track 3.
    As stated before, this happens either mic'd or line... whether or not I'm actually trying to lay down a track... all I have to do is hit record and it records all previously laid down tracks on the new track.
    I hope this clears my issue and you can help! Thanks for your response!
  • JimmyJam923 Aug 08, 2008
    I had the same problem when plugging directly into the soundcard with either the guitar or a mic. I installed a Tascam USB based audio interface and I no longer have that problem. The problem is with the computers soundcard, it wont allow playback and record at the same time.
    Champion:
  • 207 Answers
I suggest that you should pause recording every after since it will overwrite the previous songs.that's it!!
Posted on Feb 05, 2008
I am using Adobe audition 1.5 for recording my songs.. now.. i am facing big problem while using that software.. there is multitrack option available in that software. we have put karaoke track in one...
Welcome to FixYa!
I assume that you know your way around adobe audition 1.5 because I'm currently using adobe audition 3 on windows 7. The menus are different, but I'm going to give a few points that might help.
Windows Sound/Volume:
Make sure that the sound card you are using is selected, specially if you are using an additional external USB sound card (which is much better). Disable other sound cards, if any.
Adobe Audition:
One of the pull down menus located on the upper part, it has an option that says "Device Properties" or anything like that. This is where you set the input signal will be coming from and likewise the output signal.
The input signal should be the input of the sound card you selected in windows. Same goes for the output signal.
On multi-track view, check the track to be recorded. Make sure that the input is from the input of the sound card and not from anything else. The button for the setting is somewhere near the Solo/Mute/Record buttons.
If this will be set correctly, you will be able to play the song on the 1st track and record ONLY your voice on the 2nd track.
Keep me posted.
Thanks for using FixYa.
Jas247
Apr 09, 2011 | Adobe Audition 1.5
Tried to play some old tapes back and could only hear the third track? any ideas
since it is cassete recorder,may be it has magnetize by your player the last time you play it and the result is erasure of 1st and secon track..maybe you should break the plastic cover 2 edge at the bottom of your favorite cassette tape
Mar 28, 2011 | Tascam Starter Pack for 4-Track Cassette...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
When i recored my vocals they are delayed so it goes over the beat instead of being on top of it and right on point
This is a common problem with recording multi-track sounds on a computer. It is caused by something that is known as 'latency' - basically it is down to the fact that the signal from your microphone takes a different route through the system to that taken by the audio playback. The AT2020 is a USB microphone and the signal therefore has to pass through the USB bus circuit of your computer. Despite claims of multi-tasking your computer cannot do everything at once so it naturally creates delays to make itself work properly. This will be more of a problem with a computer which has a 'cut-down' processor such as a Celeron (Intel) or Duron/Sempron (AMD). These processors are really only intended for basic computing (office type) use and are not really up to the high demands of video or audio recordings.
You may get some improvement by tweaking some of the audio settings for your sound-card to change the hardware acceleration.
This article may help you http://www.pcmus.com/latency.htm
If you are using a dedicated midi /music recording program such as Cubase then you may be able to correct the time lag using the 'quantise' function after recording your vocals. However the best solution is likely to be a hardware one Either buy a proper multi-track mixer/recorder designed for the purpose or get a second USB microphone - play your backing track on an external device - using one microphone to capture your voice and one to re-record the backing track (the only downside for this second option will be a gradual degrading of the sound quality each time it is re-cycled)
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
I'm recording from cassette tape to CD and cannot figure out how to create a new track when I do it. I remember from the manual (which is lost) that a silence of ~4sec should automatically do it, but that...
Can you name the make and model? Maybe we can find a manual. I find a lot of them at retrevo.com. Just register for free and download whatever they have.
I think you have the 4 second thing backward.
Most CD Recorders will interpret a 4-second silence while recording as the end of a given track and will stop or pause. Some can can be set to leave a blank of 4 seconds between tracks (or not) when manually starting a new track. That can really be a problem on continuous recordings like live music or some classical material where brief silences occur routinely.
On my Pioneer PDR-509 there is a "Track No. Auto/Manual" selection that allows me to write a track manually whenever I want to. This is good for live or segued musical selections and doesn't require a stop/start of the recording. Of course, any time you pause or stop the track number will be incremented.
I can't really speak to the TOC errors. The fault could be with a) your machine, b) the media or c) the playback machine. The TOC is automatically created when you Finalize the disc. My machine takes 4 minutes to write it.
Little-known fact: a CD that is not finalized will not read/play on a CD player but a DVD player might play it from start to finish just fine, but without the ability to skip around because of the missing TOC. Nice to know if you mess up an original irreplaceable CD recording by not finalizing it and need to copy it over.
Jan 30, 2010 | Audio Players & Recorders
It wont record all my cd tracks, its starts
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
Nov 20, 2009 | Philips CDR765 2-Disc CD Recorder
Automatically advancing to next track while recording
Reset the machine.
Record a cd with no imput.
It worked like a charm.
Oct 06, 2009 | Tascam CD-RW750 CD Recorder
Recording second track
have you tried pressing the record button on the first track arm to stop it recording?
Jul 04, 2009 | Sony Acid Music Studio 7 Full Version for...
Magix ENTERTAINMENT Music Studio 10 deLuxe ( Windows ) (26758) Logo
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
