Question about Mintek DVA-8700 System
Rear speakers do not work , also in set up menu they are grayed out.
In the audio set up menu the center and rear speakers are grayed out. also in main menu preference is grayed out. note that when radio playing the rear speakers work, they do not work when playing dvd or cd.
  • 3 more comments
  • larry12 Feb 05, 2008
    not sure what you mean. the dvd and cd are built into the dva 8700. also under audio settings rear speakers are grayed out which means i can not activate them. please walk me through the steps neccessary as there is no mention in the book about setting up the cd and dvd menu.
    under audio setup, i have speaker setup,dolby digital setup,channel delay,channel trim,equalizer,3d processing
    looking on the remote control, i do not have a surround sound button,
    sorry my isp timed out. under dolby digital the setting are dual mono,under that are stero, l-mono,r-mono,mix-mono, then D.C.R.which gives me a slide from off to full presently set at 1/3. then then is only settings under dobly
    isp timmed out again, under equalizer type are none, rock,,pop,live,and others. then bass boost either on or off, them super bass either on or off, then treble boost either on or off. on remoter there is an audio button which when pused mono left, mono right mixed mono, stero
  • 4,102 Answers
Hi you need to acess the menu and make sure surround sound is turned on as having the wrong setting wont let you use the rear speakers it might even be button on the control.
Ill look what you need to do then i will talk you through it ok give me few minutes ok
Posted on Feb 05, 2008
  • 3 more comments
  • paul proctor Feb 05, 2008
    im looking now for you what you need to do is turn the surround sound on as it looks like it is just in stereo sound mode bare with me foe few minutes ok
    Hi What you need to do is enter setup mode then goto audio setup then in this menu select suround sound or 5.1 or 6.1.
    If you dont have this menu option on your model then its going to be on a button on cotroll you will either have an audio buton try pressing this whilst playing a film or you might have a different button depending on your model it might have a button with a circle and half circle on the button press this this should then tell you what sound mode your in keep pressing untill you get the surround sound option.
    If you still have the manual it will be in their just look under the remote section as it will tell you what the surround sound button is. ive tried looking for your manual online and cant find one but ill look again if this has given you no help just let me know ok ill look now again for you ok
    im still looking for manual cant find one anywhere have you got yours or not do you have an audio button.
    When you enter audio setup and the first menu speaker setup is this where they are greyed out tell me if im wrong.
    The next menu whats under dolby digital setup whats listed under this menu.
    Also under equalizer does this only cover the bass and treble or is their option in their other than these im asking this as im struggling to find manual whilst waiting for answer ill look again
    Im just leaving to goto work now but i will be back online in morning sorry but can you wait till then its 23:49 uk time will be back on at 10:00Am uk time hope this not a problem
  • paul proctor Feb 09, 2008
    Do you still need assistance
  • 871 Answers
Hi there
when playing radio, the rear speakers do work because you have configured that. in your dvd player however, you may not have configured it yet.
Correctly insert the jacks at the back of the dvd player and at the same time, check the menu of your dvd player and check the audio settings. Under the audio settings of your dvd player menu, select the 5.1 or 6.1 audio profile.
hope this helps.
  • earl norman llanera
    earl norman llanera Feb 05, 2008
    be sure also that the dvd/cd youve insert supports the type of audio setup you want it to. because some dvd formats does not have surround sound but only stereo sounds.
    earl norman llanera Feb 06, 2008
    Comment by larry12, posted on Feb 05, 2008
    hi larry12
    youve mention here that under audio setup, you can see "speaker setup,dolby digital setup."
    heres what you can do,
    under the speaker setup, be sure that you pre selected stereo as this will determine the sound quality of your shows.
    under dolby, look for any settings there that requires you to identify surround sound which has a rear speakers, mid...etc..
    in essense, all you need to do is identify which audio setup you want to use since you already have a surround sound hardware. the only thing thats left is to manually setup the surround sound settings which you can do in audio settings.
    so just try and try because its all there.
    hope this helps. :)
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
May 18, 2016 | Dodge Cars & Trucks
Door speaker wiring diagram for 2002 sierra
2002 GMC Sierra C1500 Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Amplifier Location: Under the center console.
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 20, 2012 | 2002 GMC Sierra 1500
Wireing diagram for a 03 gmc sierra pickup for a pioneer DEH-1200MP stereo please
Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
Feb 28, 2011 | Pioneer Car Audio & Video
I need a wiring diagram for a 2008 dodge 1500 radio
Thanks for using FixYa.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: N/A
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jan 28, 2011 | 2008 Dodge Ram Pickup 1500
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
2006 ford focus wiring diagrams
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
pls rate
Aug 21, 2010 | 2006 Ford Focus
The radio was pulled off the wiring 2005 Chevy avalanche. How do I match the after market plug to the wiring in the truck? I have the 71-2003-1 parts but the colors do not match.
2005 Chevrolet Avalanche Car Stereo Installation Guide
Car Stereo Antenna Trigger Wire: Dark Green
Car Stereo Amplifier Location: Under the Center Console.
Hope this will help you, good luck
Jan 05, 2010 | 2005 Chevrolet Avalanche
Chrysler town and country wiring diagram
2002 Chrysler Town and Country Car Stereo
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Brown
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
May 25, 2009 | 2002 Chrysler Town & Country
Factory radio wiring color codes
Here ya go. enjoy!
May 14, 2009 | 2002 GMC Sierra 1500
Rear speakers don't work
Speaker test confirms whether the speakers actually work but not the sound level you have them set at. Chack volume level of each speaker. This may be a separate button all itself.
Jan 06, 2009 | Audio Players & Recorders
257 people viewed this question
Top Mintek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mintek Audio Player and Recorder Expert? Answer questions, earn points and help others
