Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon MP530 U052 Error
The printer carritage is new, however, I'm kept getting the U052 error and cannot print. Is the printer computer chips damaged? How to solve this problem? Please help.
Many many thanks.
Ms. C
  • 8 more comments
  • Anonymous Feb 07, 2008
    Exactly the same problem. Despite repeated reinstallation of print head and ink cartridges I keep getting the U052 error telling me I have the wrong type of printhead. It's brand new - straight out of the box.....
  • Anonymous May 20, 2008
    message U052 on installing new cartridge. How do I fix this.
  • tibort Aug 13, 2008
    I also get u052 with my Canon mp520, i only have the printer since 15 march, it worked till july 15th, i did not replace anything no cartridges , and suddenly i have that message, i returned the printer head and got a new one, but still the same message.
  • sjampath Aug 15, 2008
    canon printer MP530 has error "check cartridge U052"
    How to solve it.
  • ChristineJ92 Mar 05, 2009
    My MP530 was working fine with the last set of cartridges that I had. The problem started when I put in the new cartridges. That is when the U052 error first showed up. At first I assumed it was the cartridges, but
    I ordered a second set of cartridges and the same thing happened. I checked the owner's manual and found that this error indicates that the print head needed to be cleaned, but the machine would not let me follow through with the instructions for this. No matter what I pushed, it just beeped. I have now ordered a new print head. I will see if that does the trick and post the outcome. I hope that works.
  • Anonymous Mar 08, 2009
    it just appear like tat
  • Anonymous Mar 17, 2009
    u052 error message about type head incorrect. Prompt reads,"Install the correct print head."
  • mary41 Apr 09, 2009
    Canon MP530 U052 Error - has anyone been able to solve this error? i've replaced all of the print cartridges.
  • Anonymous Apr 19, 2009
    Have the same problem. Just replaced all ink tanks with genuine Canon ones..Did NOT solve the problem..
  • Anonymous Mar 22, 2014
    I have worked through all the steps and the computer
    and printer still shows the same error message.
    Novelist:
  • 159 Answers
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Posted on Mar 22, 2008
The problem has to do with the print head, not the ink cartridges. I got this problem last week. It came without any change of ink tanks or anything. Working fine one day, error u052 the next day. Tried all sorts of button combinations - no joy. Tried changing to new ink tanks - also didn't work.
I had actually bought a replacement laser printer already, and decided I had nothing to lose (except the $100-odd stash of non-original replacement ink I had bought). I resorted to an old trick I learnt back in the days when print heads got clogged regularly. I removed the print head and soaked it in running water for about ten minutes until there was no more ink flowing out, then dried it thoroughly. Then I reinstalled the print head and inserted my previously installed ink tanks.
Believe it or not, IT WORKED! No more u052 error! I know it's not the ink tanks because when you turn on the printer with the print head installed but without the ink tanks you get a u051 error. I think the problem was just a clogged printhead.
Now I have to figure out what to do with an extra laser printer...
Just to prove that it worked, I'm posting a picture of the LCD screen!Canon MP530  U052 Error - limsoonbeng_0.jpg
Posted on Aug 11, 2011
  • 4 more comments
  • N.S. Nov 11, 2011
    I just tried this and IT WORKED! Thanks for the tip.
  • Rosalie Torres-Flores
    Rosalie Torres-Flores Jan 07, 2013
    Thank you so much!!!! Worked for me as well.
  • alan_bland
    alan_bland Feb 25, 2013
    I did but afraid it still came up with the same error message... : ( I get so annoyed with these printers always going wrong and because it\'s to expensive to get them repaired we have to go out and buy another one!
  • alan_bland
    Afraid it didn\'t work for me... I don\'t think I\'m alone when I get so annoyed with these printers always going wrong and we have to go out and buy a new one because it\'s too expensive to get fixed!
  • daltonmurf
    daltonmurf Mar 25, 2013
    this did not work for me, any other suggestions?
  • mike
    mike Oct 10, 2013
    I tried that with no change after all, what my brain cant understand is fact, that i cant use scanner (way more importatnt to me then print) becouse of some messed up cartrage printhead. I will never buy something like this anymore. Canon MP530.
    New Friend:
  • 3 Answers
Replace the print head. They wear out. Be sure to buy the correct one for your printer. I've had several different canon printers (most recently the PIXMA MP530 with this problem). After several trips to the authorized repair when they charged me for a new print head along with the service tech time, I've learned to replace it myself.
The printer is working just fine now.
Posted on Aug 09, 2013
    New Friend:
On my printer I can't print because ny printer is saing that check cartridge u052
Posted on Apr 28, 2013
    New Friend:
I have promblem with erro uo51 i have wash the head of drucke and put it i will look if it work
Posted on Mar 19, 2013
Posted on Mar 16, 2008
I have a u052 code I cleaned the head and unplug the printer it worked yesterday but the code came back can't get it to go away
CHECK CARTRIDGE
U052
Re-set the print head. If the error is not cleared, the print head
may be defective. Replace the print head.
Jul 28, 2014 | Canon PIXMA MP530 All-In-One InkJet...
U052
To try and resolve the U052 error on your PIXMA MP550, please remove the ink tanks and print head from the printer, then reseat them. If you still experience the same issue, please turn off the printer, unplug the power cord from the back and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the issue is still unresolved, unfortunately, the printer will require servicing to resolve the issue.
You can contact Cannon here: Canon Contact Us
This information originally from: My printer Canon MP530 stopped working with an Canon Forum (also has a walk through for removing the printer head and ink cartridges.)
Just so you know, the 530 and 550 are the same machine, except the 550 has a few small improvements.
Mar 31, 2014 | ErrorExpert
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Hi their My MP530 printer reads CHECK CARTRIDGE U052, the manual does not help, can anyone help me please?
Nov 19, 2009 | Canon PIXMA MP530 All-In-One InkJet...
On my Canon MP530 multifunction printer I have the Check cartrige U052 error message....
Sounds like a print head issue & might need servicing or replacement. Suggest you contact Canon direct for help.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Jul 10, 2009 | Canon PIXMA® MP530 All-In-One Printer
Reseat the Print Cartridge. Go to Canon site (see below) and search for U052 error. I followed the directions with pictures and the error went away. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Apr 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printing Error...
Hi!
The U052 error means that the 'chip' fitted to the Cartridge is not responding . They fit these chips to try to prevent refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and the chips are particularly sensitive to static / damage. Many people end up blowing the chips during the swap over
Please rate this solution.
Thanks
Rylee
Feb 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530 Check Cartridge
Im having this same problem and i dont know what to do either. Im calling canon in the morning at 8am to see what to do and i will write back to help you if it helps mine.
Jan 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
38,927 people viewed this question
old marine
old marine
