Question about iLO (2 GB) MP3 Player
Deleted files i just got mine like a week ago and i was running on low batteries. i shut it down and when i went to turn it on it said no files found. then when i shut it off it later on just like kept rebooting or something. i changed battery then it still didn't work. i plugged into comp and then it worked fine, but still no files. are they gone forever?
    Problem Solver:
  • 44 Answers
Yeah unless you still have the files on your computer. but if you dont just download them all over again.:( I know it sucks but i think it will work
Posted on Feb 06, 2008
Check Charging system light illuminates, all electrical shuts down and engine still runs on 2004 Ford Expedition 5.4l until battery dies. The opposite has also happened with the engine shutting down and...
Try replacing the "convinence control module" and bad board can cause all elec issues explained and also cause engine to cut out and other things but that is where I would start, hope this helps-
Nov 29, 2013 | 2004 Ford Expedition
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
My bike was in the shop, they replaced the battery, said they checked it out. I am in a different state, bike sat for two weeks, I went out to start it and the battery was low on juice, so, I jumped it...
I'm not sure what electronics your motorcycle has but disconnecting any "modern" electrical system from the battery while running would spell instant death to an alternator and or the computer. I'm going to say that your charging system is working or you wouldn't have been able to ride it "several miles". What I fully expect is that you have a leach (battery draw) which on a motorcycle could be an electronic clock, alarm system, fancy sound system or some other accessory that has been added. Under normal conditions two weeks on a good battery might knock it down enough not to start a quick way to check (not running) is to disconnect the positive lead and hook a digital volt between the positive lead and the positive terminal of the battery the digital volt meter will telly right there if you have a draw. If you don't then I'd be getting that battery checked out cause the short or draw could be in the battery itself. A digital volt multi meter is cheap to buy. In Canada we can get 'em for about $10.00 try it might just isolate the problem
Jan 14, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
HOW TO RETRIEVE A VERY IMPORTAN FILE
Hi nestorlayuga,
I'm assuming you have deleted this very important file? If you have not had any sudden shutting down of the computer (i.e. without going through the shut down process, like when the battery suddenly drained out) or you have not defragmented the drives meanwhile, there may still be a chance.
First, have you just 'deleted' the file by pressing a key or right clicking (which just sends it to the Recycle Bin) or have you deleted it completely by Shift+ delete or from the Recycle Bin? Check the Recycle Bin anyway, if it is still there.
If not, go here http://www.piriform.com/recuva and download the software. Run it, then enter the name of the file you want to recover, the drive it was on (if you're not sure, apply for all the drives C, D, etc) and then sit back and allow it to search. If the file is found, and if there is a green orb next to it, you can recover it easily by clicking the file and following their instructions.
If you can't find the file through Recuva, try searching in your computer just to be sure that the file is not there somewhere.
Hope this helps. Check back again if you want more help.
Mar 21, 2010 | Sharp Computers & Internet
The screen is frozen on Windows is shutting down
Turn off the power to the device, remove the battery pack.
Now replace battery pack and power supply and try rebooting.
If you still have a problem report it again on this thread.
Feb 12, 2010 | ASUS Eee 4G Notebook
No dsl signal when the phone company checks it.
it does. i had a break in my outside line that only acted up in bad weather. mine reset by itself two thousand times in two days. they replaced the damaged line and it was fine.
Jun 18, 2009 | 2wire 2700HG-B Router (2700HGB)
This is a brand new product. Every time I turn it on, I get the "shutting down" message and it proceeds to do so. I have tried 2 new batteries.
try to unlock it or reset it there shoulb be a very small hole on the back of it use something to put in there to reset it i try it i dont relly know if i works it justsomething i got off a website but i have delete all of the files off of mine and now it give me some problems because i delete my factory setsing or files so do NOT!! delete the files.
May 24, 2009 | RCA TH1602 MP3 Player
Beeping then shuts down.
Hi Speedport!
This isn't something as simple as a dead / broken / malfuctioning battery is it ? Try removing your battery, plugging the laptop into the mains and running it idle. The Bios update you found may have been a coincedence...
David
Nov 19, 2008 | Toshiba Satellite A205-S4617 Notebook
Trutech 1GB MP3 player Model SMP-1GBL
I have had a similiar problem. When I went and turned it on, the thing kept shutting off. Went to plug into computer and it wouldn't recognize. Here I found the problem. I was deleting some files from the player and I deleted the voice file. Which is what the player runs on. Do not ever delete the voice file... What I did was plug the unit into my computer. Clicked on the drive that it used to run off of. It then said I needed to format device. Went and did the format. Unfortunately it erases all the songs, so I had to redownload onto player, but now it is working properly and doesn't shut off and my computer recognizes drive.
Dec 29, 2007 | Koss CDP3600 Portable Personal MP3/CD...
I REALLY NEED HELP!
reformat your mp3 to back in original setting! reformat to software you use the twister series!
Oct 12, 2007 | Memorex MMP8564 MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
