Question about ViewSonic VX900 19" LCD Monitor
My viewsonic VX900' lcd monitor
Every time i turn the monitor on it shows a clear picture but, only for a second. can this be corrected? is this something that i can do myself? please help !
  • ny1m Feb 25, 2008
    I am experiencing the same problem with this only difference; I get no display from my PC, however I can access and view the OSD without issue. If the inverter were the problem, would I be able to see the OSD?
    Thanks!
    Problem Solver:
  • 22 Answers
Replace your monitor, it's broken
Posted on Feb 25, 2008
Your backlight inverter is likely to be broken, can't hold the charges.
Part#: DAC-12C024MSS
see following link for self replace the parts:
http://www.lcdpart.com/images/ViewSonic_VX900.pdf
    Brigadier General:
  • 6,966 Answers
There could be a couple of possible reasons for your problem:
1. All LCD displays uses CCFLamp to illuminate and provide backlight to the panel. More often they burn out or thier connectors gets corroded or the circuitry that powers these lamps gets defective. Defect can either be component failure or loose/cold solder joints. At times it could be the capacitors that dries out or have developed blisters on the top portion.
2. There had been cases where it is the power supply of the monitor that is in problematic.
3. In some cases, it is not the monitor that has a problem, it may be the video card of and/or the PC itself. This could be confirmed by using another monitor to eliminate this possibility. At certain times, it may be due to the Screen Resolution settings of the PC or the Screen Refresh Rate.
Things you can try:
a. Boot your PC normally even if you cannot see anything. Shine a flashlight obliquely to the screen. If you can see semblance of your desktop no matter how dim, then you have just confirmed that it is the backlight/CCFLamp or its inverter that is the problem. this is repairable but would require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron;
b. Internal or external power supply for LCD display panels/monitors are likewise repairable. Again the same requirement if you are to proceed doing the repairs.
c. Adjusting the Screen resolution and Refresh Rate can be done in the PC by booting into Safe Mode and lowering the settings.
Should you not be comfortable on options 1 & 2, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 05, 2008
Lost remote for ViewSonic 19" VX900 Monitor.
Please verify the model number since VX900 is just a monitor, it does not have any remote function, http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 13, 2011 | ViewSonic VX900 19" LCD Monitor
My screen only shows a picture for a few seconds
Try connecting a different monitor to your computer, to see if that monitor shows the same symptoms. If so, your computer, not your monitor, is the problem.
Try connecting your monitor to a different computer (desktop or laptop) to see if the problem "follows" the monitor.
Jul 17, 2010 | ViewSonic VX900 19" LCD Monitor
VX900 19 in. Flat Panel LCD Monitor: when i turn it on the screen is black....
You may have backlight inverter failure, check the fuse as shown in my pictures, you can also have bad backlight assemblies also, but check the fuse on the inverter bd first, verify that you do have 12v at the fuse.
May 16, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
View sonic VX900 how do I install monitor
Home ViewSonic Monitor VX900. Download ViewSonic Monitor Driver ... Install Windows Driver How to install a Windows Driver properly and avoid possible problems? ...www.nodevice.com/driver/VX900/get36587.html
Dec 04, 2009 | ViewSonic VX900 19" Flat Panel LCD Monitor
Viewsonic VX900 LCD Monitor No Display.Bcklt and Screen Menu Work
It looks like you have to replace mainboard (it doesn't take input signals)
Mar 26, 2017 | ViewSonic VX910 19" LCD Monitor
Viewsonic VX900 turns on/shows image for a second then shuts off
SOUNDS LIKE A BAD POWER CONTROL BOARD PROBABLY NEED TO REPLACE MONITOR
Jan 15, 2008 | ViewSonic VX900 19" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VX900 19" LCD Monitor Logo
173 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
