I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
  • raddio Feb 05, 2008
    The model of the dvd player is philips dvp 520105, do not know age of model.
    The model is philips dvp 520105. All I need is the code to set it to play multiregion, I have worked everything else out but 95% of my dvds are from the USA and I have been unable to watch them.
    President:
  • 1,944 Answers
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
Posted on Feb 05, 2008
    Sergeant:
  • 226 Answers
What is your dvd player?
1. Sony DVP-S525D
I inherited a dvd player - sony-dvp-s525d.gif This hack should give you access to a service menu containing controls for macro-vision and region coding.
1. Set your player to Standby
2. Press Title, Clear and Power
It's as simple as that!
3. Cyberhome AD-N 212
How to convert your Cyberhome AD-N 212 player into a multi-region compatible machine
This hack also works on the Cyberhome AD-M 512 player
To convert this player to Multi-Region
1. Open the drive tray
2. Press the 7 button on your remote control
3. Press the 6 button on your remote control
4. Press the SEL button on your remote control
5. You will now enter the hidden setup page, and can change the player to any Region or set it to Region Free by entering 13 as the country code.
5. Proline DVD-1000
prolinedvd1000.gif How to convert your Proline DVD-1000 player into a multi-region compatible machine
Note this hack also works on the Wharfedale DVD-750, Bush DVD-2000, Grundig GDV-200 and Grundig GDV-210
1. Open the disc tray
2. Place a region 1 disc in the tray, but don't close it
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time
4. Press the Play button on either your remote or the player
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control
3. Press the Return button on your remote control
4. Your player should now go into Standby mode
5. Press the Power button on your remote control To return this player to Region 2 only (alternative method)
6. Open the disc tray
7. Place a region 2 disc in the tray, but don't close it
8. Press the buttons Return and then Play on your remote control in order, one at a time
  • earl llanera
    earl llanera Feb 05, 2008
    13. Samsung SV-DVD3E DVD-VHS combo player
    How to convert your Samsung SV-DVD3E DVD-VHS combo player into a multi-region compatible machine.
    Always perform a Cold Start before applying the hack below
    1. Power on your player
    2. Press and hold both the Play and Stop buttons on the player NB: If the above does not work, then press and hold the Play and Forward buttons on your player instead
    3. After a short while the words No Disc should disappear from the onscreen display. Release the Play and Stop buttons on the player
    4. In some cases you may now need to turn your player off and then back on
    To convert this player to Multi-Region playback
    1. Press the Subtitle button on your remote control
    2. Press the Repeat button on your remote control NB: If the hack does not work then repeat it WITHOUT performing this step
    3. Using your remote control enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate for
    • Region 1 use 2, 9, 3, 3 and 4
    • Region 2 use 3, 8, 7, 6 and 7
    • Region 3 use 5, 6, 7, 3 and 2
    • Region 4 use 7, 6, 8, 8 and 4
    • Region 5 use 5, 3, 8, 1 and 4
    • Region 6 use 2, 4, 4, 6 and 2
    4. A code should be displayed on the screen indicating the current Region setting of your unit.
    5. Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
    6. Press the Open button on your player
    7. Press the Standby button on your remote control
    To reset the machine to its factory defaults
    2. Press and hold the FF and REW buttons on the player for three seconds
    3. The firmware version will be displayed and the machine reset to its original configuration
    14. Scan SC-2000
    How to convert your Scan SC-2000 player into a multi-region compatible machine
    Note this hack also works on the Daewoo DQD-200 / DHC2200, DHC2300, Logix DVD-3000 and Manhattan DVD-2000
    To convert this player to Multi-Region on later firmware versions
    1. Press the Open button on your remote control
    2. Press the Setup button on your remote control
    3. Press the 9 button on your remote control for Region Free, or 1 for Region 1, 2 for Region 2, and so on.
    4. Press the buttons 2, 0, 1 and then 0 on your remote control in order, one at a time NB: If this doesn't work, you should try pressing the buttons 3, 0, 1 and then 0 instead NB: If this still doesn't work, you should try pressing the buttons 4, 0, 1 and then 0 instead
    5. Press the Step button on your remote control
    6. Press the Shuffle button on your remote control
    7. Press the Next button on your remote control T
    To check the current region setting of this player on later firmware versions
    3. Press the Shuffle button on your remote control
    4. Press the Step button on your remote control
    5. Press the Next button on your remote control
    6. A secret menu will appear, inside which you can scroll down until the words Debug Item appears, where the current region status is displayed
    To fix low sound output volumes when connecting to your TV via SCART on later firmware versions
    1. Press the Setup button on your remote control
    2. Press the Stop button on your remote control
    3. Press the Step button on your remote control
    4. Press the Angle button on your remote control
    5. The word RFOUT will appear on screen briefly and the sound will now have been adjusted to normal levels
    To convert this player to Multi-Region on earlier firmware versions
    2. Press the Title button on your remote control
    4. Press the Next button on your remote control
    5. Using the Up and Down buttons on your remote, select the region of your choice or Bypass for region free
    6. Save and then Exit the menu
    15. Hyundai DVD-320A
    How to convert your Hyundai DVD-320A player into a multi-region compatible machine
    To change the region on this player on newer models
    1. Using your remote control, press the buttons 7 and 7, in order, one at a time
    2. Press the Play button on your remote control
    3. You should now be in a hidden menu
    4. Using the Up and Down buttons on your remote control, highlight the Country Code option
    5. Press the Enter button on your remote control
    6. Using your remote control, press the 1 button for region 1, 2 for region 2, and so on, or 0 for multi-region playback
    7. Press the Enter button on your remote control
    8. Press the Play button on your remote control
    To change the region on this player on older models
    1. Press the Open/Close button on your remote control to open the disc tray
    2. Press the 3 button on your remote control
    3. Press the 8 button on your remote control
    4. Press the 0 button on your remote control
    5. Press the 0 button on your remote control
    6. Press the Menu button on your remote control
    7. Using the arrow buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on
    8. Press the Enter button on your remote control
    9. Press the Menu button on your remote control
  • earl llanera
    i gave you the brands. choose what brand are u using
    Genius:
  • 3,422 Answers
HI,
Can u tell me whats the model no. and the brand??
So that i can help u to fix it..
  • Priya darshan Feb 05, 2008
    First try this method:
    1. Press the System Menu button on your remote control
    2. Using your remote control, highlight the Preferences menu
    3. Press the 1 button on your remote control
    4. Press the 3 button on your remote control
    5. Press the 5 button on your remote control
    6. Press the 5 button on your remote control
    7. Press the 6 button on your remote control
    8. Press the 6 button on your remote control
    9. You should now be in the hidden region selection menu were you can use the Up and Down buttons on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 0 formulti-region playback
    10. Press the System Menu button on your remote control
    Then if the above method doesn't work try this:
    press setup
    go to the prefernces page.
    type 9 6 5 3
    Press Arrow key up or down and select 0 for region free
    Hit ok
    Gooduck,
    Please don't forget to rate me as fixya..
    You can also try this one:
    Try: -
    1. Open tray
    2. On R/C press 9 8 7 9 0 for
    region free
    OR
    1) Open the tray of your DVD Player (otherwise you
    can’t access the preferences menu!)
    2) Go to Preferences in the Setup Menu
    and enter 1-3-8-9-3-1 with your RC
    3) Options appear: Chose region 0 in
    order to play all DVD's
  • 1,512 Answers
Hi there
I you can give me the make and model I can find a book for you:)
regards
Graeme
  • 2 more comments
  • Graeme Ross
    Graeme Ross Feb 05, 2008
    and a procedure to recode the machine is often possible too... depending on the make and model of course :)
  • Graeme Ross
    It appears you have gone with CoolGuy to find this for you... Good luck mate.
  • Graeme Ross
    This site has assistance or all models of DVD. If you can get a fix with the above... these guys may be able to help
  • Graeme Ross
    Graeme Ross Feb 06, 2008
    whoops sorry, forgot to paste the link
    http://www.dvdunlocks4u.com/
DVD region hack available?
no such thing exists
JVC HR-XVC1U region code - VideoHelp
www.videohelp.com/dvdhacks/jvc-hr-xvc1u/1143
  1. Cached
DVD Hacks > JVC HR-XVC1U region code hack. ... What are Blu-ray and DVD region codes, country codes, multi-region or zone locks? Read DVD Player ...
DVD Player and Blu-ray Player region codes - VideoHelp
www.videohelp.com/dvdhacks?dvdplayer...hits=25&listall...
  1. Cached
What are Blu-ray and DVD region codes, country codes, multi-region or zone ... 12382 DVD Hack hits, Showing 3276 to 3300 DVD Hacks ... JVC HR-XVC1U
JVC HR-XVC1U DVD Player/VCR Multi region hack ... - Fixya
www.fixya.com > ... > JVC > JVC HR-XVC1U DVD Player/VCR
  1. Cached
multi-region code hack is there a multi-region code hack for a Toshiba SD 370E dvd player? Can you help? I need the multi region code for my Toshiba DVD ...
JVC HR-XVC1U DVD Player/VCR Hack - Questions - Fixya
  1. Cached
will not play all regoins You need to hack the player to get all regions. There are a lot of web sites tthat carry the information you require. Some models dont hack ...
JVC HR-XVC1U - DVD Players - Retrevo
www.retrevo.com > Blu-ray / DVD Players > JVC Blu-ray / DVD Players
  1. Cached
JVC HR-XVC1U: No region hack for this player. Post region code/hack here. ... Harmony 880 w/ JVC HR-XVC1U VCR/DVD Combo- Help - Logitech Forums.
JVC HR-XVC1UC - DVD Players - Retrevo
  1. Cached
Learn more about the JVC HR-XVC1UC before you decide to buy. Download User ... www.videohelp.com. JVC HR-XVC1U: No region hack for this player.
May 03, 2016 | JVC HR-XVC1U DVD-VCR Combo
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
Jun 07, 2013 | Pioneer DV2032K All Multi Region Code...
What is the multi-region code for Toshiba DVD Player SD5300KC
These WEB sites may have a region free code for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 03, 2013 | Toshiba SD-3900 DVD Player
I ordered a dvd that has been out for years online, and tried to play it, It won't play- saying region code, how can I change the region code?
Greetings Sandy - Sorry there is no known way to change the region code on that player. For some players there are region "hacks" that will allow the playing of discs from different regions.
If you know anyone who has the ability to copy DVD's to their PC and create another DVD that would be the only way around the problem.
Ask your more computer literate family and friends to see if any one knows how to do that.
Regards and thanks for using Fix Ya.
Mikeywaf
Apr 15, 2011 | Magnavox NB500MG1F Player
Wrong disk?
is the dvd multi region can it play disks from other countries if not find the codes for it by searching the name of the dvd player eg samsung unlock codes ........hope this helps
Jul 17, 2009 | NexxTech N600D DVD Player
Convert US DVD in Region 1 to play in UK Region 2
Please go to codemasters.com , type in the details of your dvd player, there will be several region code hacks ,follow the instructions and this should work for you, basically you are needing to make your dvd player a multiregion player. all dvd players are multi region at time of manufacture, but they are code set for the county that they are shipped to, hopefully this should help. you can also go on to google type in Hack for whaterver your dvd player is and you will get a region code there.
best Wishes
jimba
May 28, 2009 | Philips Televison & Video
Multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Feb 29, 2008 | Philips DVP3140
Yamaha DVD S1700 player multi-region unlock code
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Nov 18, 2007 | Televison & Video
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
