Question about RCA HD50LPW42 50" Rear Projection HDTV
Green light On Off
Problem HD50LPW42 Green light comes on then off Two or three tomes Then sound come on.Then after two or three times.The lamp will come on .After warm up its OK. I do not think it is the lamp.Its before the lamp.When lamp gets power it is fine.Would it be the Ballast??Thank for help.
  • Billie_95 Feb 25, 2008
    I put a new lamp in and still doing it.Took it in and it was a ballist cost me $392.12 to fix it plus 127.00 for lamp i did not need,But have a spare now. Thanks.
    Problem Solver:
  • 11 Answers
You should listen for a strike noise at the lamp or ballast area, 1 strike for each cycle. A weak lamp will take more strikes to start, until one day it never starts.
Posted on Feb 06, 2008
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
I have a RCA HD50LPW42, the tv stopped showing the picture awhile back but the sound continued when the tv was turned on. Now the sound has gone out too. When I turn the tv on the green power light blinks...
You may have two problems with your TV. This TV has a history of a color wheel issue, was making grinding noise? Have you ever changed the lamp?
It may be a bad color wheel and the lamp, you may want to do a visual inspection.
It is easy to replace the lamp but more likely the color wheel is the problem.
The part# for the color wheel is 212184, the part# for the lamp is 260962
Best of luck
Nour Sabre
Nov 16, 2011 | RCA HD50LPW42 50" Rear Projection HDTV
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Mar 17, 2010 | Televison & Video
HD50LPW42 making noise near lamp
colour wheel doesnot have bearing.but if its faulty it makes some gearing noise or click click noise.check out.
Jul 13, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Tv no picture makes sound like cricket three times, green light on then shuts down and lamp light comes on, most of the time but sometimes just shuts down completely
lamp light flashing? possibly going out and needs replacing. google search the model number and lamp replacement, you might get lucky and find a replacement. around $250.
Jul 12, 2009 | Televison & Video
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
RCA HD50LPW42 50" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
