Question about RCA HD52W56 52" Rear Projection HDTV
Three screens at once!
We are trying desperately to remove the three/split screen and get back to one! Somehow we have punched something on the romote or TV and have three identical views of the same thing... all three are thin and "bunched up" What to do? Jenro
  • RCA Master
  • 5,138 Answers
On this make and model to fix convergence problem replace FL231 400ma. this will fix convergence also it is located right in front of flyback.
Posted on Feb 18, 2008
    Champion:
  • 208 Answers
This is a convergence problem. Go into menu, select setup, select convergence, and run auth converge. If there is no failure in the tv then this will correct the problem. This model does have chronic convergence failures and most times either the convergence power supply must be replaced. Occasionally the problem is the convergence amp pcb and rarely the deflection bd can cause the problem.
Posted on Feb 09, 2008
I have DEG on the calculator screen and get figure out how to turn it off??
Press the DRG key to cycle through the three angle modes. Be aware that whatever mode you select, the corresponding indicator will appear on the screen.
The angle mode should not affect the exponential and logarithmic functions. If you still get errors, please post an example or two, including the exact keystroke sequences.
Dec 11, 2013 | Texas Instruments TI 30XIIS Scientific...
Tip
How to remove moisture from between a Projection TV Screen.
You tried to clean your projection TV screen with windex and sprayed it onto the screen. Later you notice that there is liquid between the screens. How do you get it out?
First your screen is composed of three pieces. It may not look like it but there are three pieces of plastic making up the screen. If any liquid gets between them you will have an anoying problem.
You will have to remove the speaker grille to get to the screws that hold the screen on. Pulling gently on the side of the grille you should be able to get the grille to pop off. Move your fingers around the grille to continue removing it. Do not force the screen but pull on it steady.
Once off you should see the screws holding the screen on at the bottom of the screen. Remove all screws. If you have magic focus you will need to remove the back first so that you can disconnect the wires to the sensors. Removing the back is simple and only requires the removal of the screws around the perimeter of the back assembly.
Once this is done grab the screen on both sides and lift it straight up. You may have to tug to break it loose. Once off the screen can be removed from the frame by removing all the screws around the perimeter.
You should be able to separate the screens (there are three) with a razor knife and dry them. I would leave the screens apart for a few days after wiping the liquid off just to make sure there is no moisture left.
Reassemble the screen as it was prior to disassembly and use duct tape or black tape around the edge to hold it together. Place it back in the bezel and reassemble the unit. It should be good and have no moisture problems.
Thanks for using FixYa .
hardrocko
on Oct 28, 2010 | Televison & Video
When i open up the camera app. i see black specs all over the screen, it looks like dirt in there or something. Is there a way to clean it?
Three possibilities..
1. Dirt on the outside of the lens. Clean it with a lens cloth.
2. Something got inside the lens somehow. Do not take it apart yourself. Have a proffesional clean it.
3. The LCD screen is bad.
Feb 28, 2011 | Cameras
Water has got behind plastic screen, can you remove and dry the screen?
sandiboat,
Your screen is composed of three pieces. First you will have to remove the speaker grille to get to the screws that hold the screen on. Pulling gently on the side of the grille you should be able to get the grille to pop off. Move your fingers around the grille to continue removing it. Once off you should see the screws holding the screen on at the bottom of the screen. Remove all screws. If you have magic focus you will need to remove the back first so that you can disconnect the wires to the sensors. Once this is done grab the screen on both sides and lift it straight up. You may have to tug to break it loose. Once off the screen can be removed from the frame by removing all the screws around the perimeter. You should be able to separate the screens (there are three) with a razor knife and dry them. I would leave the screens apart for a few days after wiping the liquid off just to make sure there is no moisture left. Reassemble the screen as it was prior to disassembly and use duct tape or black tape around the edge to hold it together. Place it back in the bezel and reassemble the unit. It should be good and have no moisture problems.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 28, 2010 | Hitachi 51F59 51" HDTV Projection...
MY DAUGHTER SOMEHOW ENLARGED MY SCREEN AND I CAN'T UNLOCK IT
you can double tap the screen with three fingers simultaneously and that it will go back to normal three finger tap is zoom functionality of iphone 3G-S added feature
Aug 07, 2010 | Apple iPhone Smartphone
My lg laptop screen seems to be split in 2 almost. It only shows three quarters of the screen and at the bottom the screen starts again
Try to turn off the pc and remove the cables and battery on the laptop. Press and hold the power button for 5 seconds, then reinsert the battery and the cables on the pc. Turn on your laptop and check if the screen will finally splits sucessfully...
May 15, 2010 | Computers & Internet
Screen on Sony VAIO PCG-SRX99 needs to be tightened.
you will have to take the bezel front plate of the screen off and check to see if anything there has broken from the hinges. there are usually two-three screws holding the hinge to the screens back cover and two-three holding it in place on the base of the laptop. if all those are intact you will need to replace the hinges.
good luck
ruben
Apr 06, 2009 | Sony VAIO SRX99 Notebook
Samsung hdtv HLP5085wx no image. Smelled something burning and sparking, turned off the tv. Tried turning it back on = have sound, NO image!
OMG! Dude, your screen is just plain fried. You don't need a new screen though, You just need a new bulb for it. See, behind the screen is a light bulb (unless your T.V. is plasma screen), sometimes two or three, and that burning smell was the bulb blowing (like when you need to replace a light bulb in a lamp or something). I don't know where you can find a new bulb, but once you replace it everything should be fine.
Oct 05, 2008 | Televison & Video
Split Screen
there is a button on the back,black one switch it and ur problem will be solved.....
Mar 29, 2008 | Memorex MVD4543A
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
