Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Model#110.29842991 top load washer
How to put in the switch, Lid switch
  • 20 Answers
You should be able to pop the top up, the switch should be up inside the the top, unplg the switch and install the new one.
Posted on Feb 06, 2008
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
The contact button (part where you put the door down to make the washer start to agitate) something came apart....washer is filled with water and now won't go. The part came out.
you broke the lid switch,send the full model number located under the lid,lift the lid up,follow the lid to the bottom and look right under it and you'll see the model number,it will start with like 110.
Aug 30, 2011 | Kenmore 22422 Top Load Washer
The machine suddenly stop working right after finishing water had filled (the next action should start its washing cycle). Then there is no response, just as electricity is disconnected from it. Thank...
try opening the lid a couple of inches and close it down a few times,do you hear a clicking sound?if not the lid switch is bad.on the right side of the lid you should see a piece of plastic connected to the lid that fits into a hole in the top of the washer,this hits the lid switch,stick a pen or something in the hole and see if the washer works,send the model number and i'll tell you what switch you have on your washer,the model number is on the back wall of the opening where you put the clothes into the washer or to the left of the lid switch.if your lid opens strait up and backwards the number is directly under the lid when it's in the open position
Aug 07, 2010 | Kenmore 24642 Top Load Washer
My whirlpool washer will not go to drain cycle . i put it on regular wash it fills and aggitates but when it stops it stops .
If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the model number you have this listed under is correct, the part number for a replacement lid switch is 3949247. This is a very simple repair, that usually costs about $30 to repair yourself., and usually have excellent exploded view diagrams of what I am referring to. Just type in your model number and look under the "Top and Cabinet Parts" section. The lid switch is listed as item 11 and the lid strike is listed as item 20.
If you have questions, or require additional assistance, please let me know. Post back with a correct model number if the model number is not correct. I hope this helps you.
Oct 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmoore washer , model 2262210 serial cl4434210, type111 . will not spin and does not drain . what are the possible problems . please help . thanks . T.W.N. at
if this is a traditional top load washer, then your lid switch might be bad. Usually when this happens, your washer will start fine. Your put it for a normal wash, it does its thing, lets in water, and agitate and stuff, but when it goes to the spin cycle. it stays in that cycle and wont advance. Leaving you with a tub full of water. Like i said if its a traditional top load kenmore, the lid switch is the the gray looking part when you open your lid. when you open your lid, youll see two screws holding it. But you have to take the whole shell of the waher to get to it....take 2 screws on the back corners of the counsel, then flip the counsel up. Locate to metal clips and pop them put with screwdriver. unclip the lid switch connector located by the clear hose that runs down. then lift and pull the whole shell towards your and acess the switch from underneath. put back together how you took it apart.( MAKE SURE THE CLEAR HOSE THAT RUNS FROM THE TOP COUNSEL TO THE TUB DONT GET PINCHED BECAUSE YOUR WASHER WILL OVERFLOW WITH WATER) like i said if its a tradidonal top load kenmore....hope this helps
Aug 12, 2009 | Washing Machines
Need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Please remember to leave a rating
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal De
