Question about Acer Aspire™ T180 PC Desktop
My computer is on but is not giving no power
The light that you push to turn the desktop on it;s not coming on the the cpu is on i can open the disc tray and all but the computer is not givig no power the light don't come on.
Check the VGA graphic chip is working or not by connecting in to another computer.
please see the ram and fix another ram or another method
take out the cmos pin outside and after 5 minutes fix it and see it will be alright
Posted on Feb 09, 2008
    Champion:
  • 207 Answers
Try check the connections of your motherboard..check the wire connections( the one that is twisted type wire), try to push it gently towards the board to fit properly but dont pull out the wires as if you don't loose connections from the motherboard.ok?
Goodluck!!
Posted on Feb 05, 2008
My computer will not start, the power button lights up the the lights on the front panel will not come on so I cannot get it started.
Well It sounds like the computer is getting power, so that's good news.however, the CPU is the brain of the computer and without it unfortunately it will not work, but I don't think your CPU is the problem. With the new windows update I had this happen to me also. You can try holding down alt+f4 when you power on your computer. A blue screen should appear and give you options to troubleshoot. You will need to retrieve your files from a previous update which will take a few minutes. If that does not work then you may need to take your PC into a repair shop.
Mar 17, 2015 | Acer Aspire Desktop Computer - Intel Core...
My Compaq Presario sr5410f won't power up...the switch lights up but the system won't come on...please help
Out in internet world there are 2 main reasons for this:
1) You need a new power supply.
2) Your CPU is overheating. Check fans are working and give it a good cleaning.
HP computers do this a lot. Some have come back by leaving them off for a day or 2. Others come back by disconnecting it fromt he wall. pushing the power button a few times (this clears any electrical charge that may be in the system).
Good Luck.
Feb 08, 2015 | Compaq Computers & Internet
Push power button and the power light turns amber and lights up then shuts off. the light in back of the computer is light green and it starts to turn on then dies
The fact that ity is trying to start and shuts off after ..it seams that it is the CPU fan to blame ...If the fan fails to start the CPU will turn the computer down instantly due to the temperature limit ..(in 1 or 2 sec ) ..
so ...open it up ..and see if the fan is spinning ...on start ..and if it is not ...check the connection with the board or replace it ..
(by the way ..this may also be a CPU failure ..and need another one ) ..
Aug 31, 2011 | Dell Inspiron 518 Desktop Computer
My iBUYPOWER Gamer Power A557D3 FPS Gaming Desktop want turn on have it pluged in and the little green light is on that shows the mother board has power but it want turn on
The best thing to do is to claim warranty support on your computer system from the place of purchase, if however that otion is not available to you, you may go through my published guides. They are listed below:
How to Remove the Side Panels of My Computer Chassis!!!
My Computer is not turning on!!! Is it dead!!! No POST!!!
How do I reset my BIOS/CMOS to defaults?
The problem may be a loose connection, be sure to push in all drives and fan connectors as well as the 4Pin CPU and 24Pin Mainboard Power connectors.
Give it a clean if need be.
Thanks
damnor01
Mar 16, 2011 | iBuyPower Gamer Power A557D3 FPS Gaming...
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Push Button and Computer fan starts then immediately shuts off (1 Second) .Yellow light on front does the same comes on 1 second then off .Nothing else happens . It is a Dell Dual Core 2 fans.
chek your power unit or the cpu fan working or not if the cpu fan is not working computer will turnoff immediate to save it you better show you computer for technician soon
please rate this solution.....
Apr 11, 2010 | Dell Inspiron 531s Desktop Computer
Had a power outage and the computer won't come back on. Compaq Presario Desktop - SR1230NX
open CPU cabinet and give power to computer thencheck your smps is working?
it is square box where you connect power code to cpu.
If its running then it is ok.Then check for loose connection from smps to motherbord.
But if its not working then you have to change smps or repair it.
Thanks for using fixya.
Please rate solution if it helps.
Jul 25, 2009 | Computers & Internet
My cpu will not power up the blue light just flashes when pushed and held
Flashing power light is a sign of a hardware failure. First unplug the pc and give it about 30 seconds then turn it back on. If it goes back to a blinking power light you have a hardware issue and will have to get that checked out.
Jun 22, 2009 | Gateway 560GE PC Desktop
Computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Feb 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Acer Aspire™ T180 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
