Question about HP DeskJet 1000cxi InkJet Printer
HP 1000C inkjet
The clear plastic ribbon that spans from one end to the other behind the carriage has come off its bracket. How do I reattach it and where?
  • 152 Answers
Plastic ribbon is "encoder strip"
encoder strip fitted in carriage block unit
Posted on Feb 28, 2008
  • Harshad Patel
    Harshad Patel Feb 28, 2008
    encoder strip right hand side and left hand side hook
    insert strip in carridge block phto diode sensor
  • Harshad Patel
    carradge block sensor
HP 2175 all in one. I have a carriage jam that will not clear. There is no paper jammed anywhere. I have been through all that and I have tried all the reset options but nothing works. But I notice a...
Not sure about your model. But that ribbon is very likely the cord that send information to your print cartridge. It is supposed to be slack so that the print cartridges can move left and right. If you are able to reconnect it and make it stay you should be good. Likely when it is in the furthest position it is getting too tight and coming loose again. Hopes this helps.
Mar 11, 2017 | HP PSC 2175 All-In-One InkJet Printer
1000Cxi inkjet
Click here to see the manual and go through it carefully, you will find a solution to ur problem..
You need to have adobe acrobat reader to view the manual in pdf format.
Click here to download it if u don't have..
Please don't forget to rate me as fixya..
Feb 05, 2008 | HP DeskJet 1000cxi InkJet Printer
The print carriage travels along a thin plastic ribbon cable which is normally attached at either end of the print area by 2 metal 'pins'. This ribbon cable has become unattached at both ends. I see how to...
You have to remove most of the casing to access the workings. It is a tricky job as bits all plastic, click together with push fit plastic locks, and of course an occassional hidden screw.
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Check to make sure that the front top of the L bracket that shields the ink tubes on the carriage is not rubbing against the inside top front metal edge that is just behind the clear plastic cover. And make sure your rails are cleaned and then oiled with NYE oil. There is a problem with the design of this machine, where there is a bracket on the top of the carriage assembly that pushes the ink tubes towards the inside front of the machine causing unneccesary rubbing.
Jan 27, 2010 | HP DesignJet 1050c InkJet Printer
Where is the carrriage located on my hp 7310 officejet printer?
The carriage is the unit that holds your ink cartridges, usually parked on the right side. When you have carriage stall or carriage jam you usually need to clean the clear plastic strip that runs across behind the carriage assembly, and make sure there are no scraps stopping the travel of the carriage.
Dec 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 6110xi -clear carriage jam
Nov 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Carraige return pull came off
I'm assuming you mean the strip of translucent plastic on which the carriage runs. I was able to reattach mine - it requires small hands and a flashlight, as well as some patience!
The punched-out holes at each end of the strip have to be correctly aligned to fit into the metal prongs (I found the left side to be most difficult). It took me four or so tries and about twenty minutes.
May 03, 2008 | HP PSC 750 All-In-One InkJet Printer
Carriage Jam
first of all,just look for any obstruction or any peice of paper,specially where the carriage rest ,check the carriage belt is it look physically ok,check a transparent stripe which is behind the carriage unit it passes through the circuit behind the carriage,check all n revert accordingly
thnx N
Jan 23, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP DeskJet 1000cxi InkJet Printer Logo
246 people viewed this question
Ben Johnson
