Question about Panasonic KX-TG5632 Phone
Answering phone system cannot handle nuisance calls
With this new phone, if we get a nuisance call, identified by caller ID, we let it ring until the answering system cuts in. Then the phone seems to be recording, but it soon gives a dial tone and the operator saying "If you want to make a call, please hang up and dial again." The only way to shut this off is to answer the call and then hang up the phone. We get about two or three of these a day. We tried to solve this by increasing the rings before recording from 4 to 5. No help.
With our earlier phone, we occasionally got the same situation (dial tone and auto message), but most of the time the robocall hung up before this all started. Maybe had this situation once a week.
Is there something in the Panasonic answering mechanism that keeps it active until the dial tone and auto operator come on?
  • Anonymous Oct 13, 2008
    At the end of all calls picked up by the answering machine, we get the "If you'd like to make a call" recorded message - even after the ones that successfully leave a message. This is for the KX-TG5634 model.
I have problem with my phone (TX TCA115UA B)
i can not turn on the tone regime (now is on pulse regime when i dile the number)
Posted on Mar 18, 2008
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
How do I identify an incoming phone number?
You need to have Caller ID from your phone Co. 1st. Then when you get a call the number shows up as the phone rings.The handset also has a button called,CID,which you can press and see the last 100 calls you've recieved:)
Sep 27, 2014 | Uniden D1680-3 Cordless Phone - Dect 1 x...
How to change number of rings on VTect cordless CS6114-11
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | VTech Communications CS6114 - cordless...
How to change number of rings on Vtech cordless phone
The 6041 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
Jul 30, 2014 | Vtech Cordless 6041 Phone
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
How to set ringer from 2 rings to 4 or more on v-tech vtcs6114
The CS6114 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
If you have an answering machine connected to your phone, consult its documentation. If you need further assistance, please repost your question and identify the answering machine.
Feb 26, 2013 | New Vtech Vtcs6114 Dect 6.0 Single Handset...
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
KX-TG9344
This is the info from the users manual, it seems a bit strange,
but claims if you set the number of rings before it answers, (for the answering system) to "2" it will stop the audible caller ID.
Here it is from the manual.
If you turn on the answering system
and set the number of rings “2” (page
38), the unit does not announce the
caller information. If “Toll saver” is
selected and there is a new message,
the unit does not announce the caller
information.
When you receive a call while on the
phone, the 2nd caller’s name is not
announced even if you subscribe to
both Caller ID and Call Waiting with
Caller ID services
Jan 02, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG5632 Phone Logo
227 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
