Question about Lexmark X85 All-In-One InkJet Printer
Printer stopped printing abruptly.
My computer stopped printing. There was no indication as to why. If I am out of ink, the printer usually warns me by giving weak copies which was not true this time. I have tried putting new discs but that only made things worse. Now something happens called "carrier stall."
I should probably get a new printer but I cannot afford one now.
  • Anonymous Nov 19, 2008
    My printer just stopped printing. Ive tried restarting it from the main power and from the on/off switch. i cant figure it out. it was fine an hour ago.
    help!
    President:
  • 1,944 Answers
Did you try turning it off and disconnecting it from the power for a few hours so it will reset?
Posted on Feb 05, 2008
PLEASE HELP! jusr bough and installed/setup my new Epson Artisan 710 printer. All the lights keep flashing and I have a message on the printer screen that says: "WARNING - move the yellow material as...
"All lights blinking and printer not responding" is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
The Solution is to try an older/another cartridge (doesn't matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper "dots".
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge's electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Good Luck & God bless!
Feb 11, 2011 | Epson Artisan 710 AllInOne InkJet Printer
I cannot check the level of ink in my hp 5610 model printer
You need the HP Toolbox software: Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
Bypassing printer warning that stops my printer
this one is one of my favourite hate printers... but, no you cannot disabel this function easy, you can "fool" this printer by following that procedure:
1. switch off your printer, wait few sec, switch it on
2. on your computer go to "start"
3. select "control panel"
4. select "printer and faxes"
5. right click on your "kodak easyshare 5300"
6. select "properties"
7. click on tab "services"
8. select "service this device"
9. click on tab "estimated ink level" - it shows estimated ink level after restart
you can use refill (very easy to do by yourself and about 1/3 cost of original replacements). and yes, you are right, cartridges do tend to dry out. i would suggest printing at least one page per week to prevent dry out of the cartridge.
as this particular printer will not work without both cartridges present. i would suggest to insert one empty cartrdge in colour slot and keep it there. on full cartridge use any sticky tape to prevent nozzle from drying, cover breather hole on the top of cartridge as well. when you need to print, remove tape from breathing hole first and then from the nozzle. this way you will prevent or at least slow down your cartridge evaporation ratio.
Jul 28, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have installed a new ink cartridge but it still will not print saying it is out of ink
The low ink warning if you are using remanufactured cartridges.Even if you aren't, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. The warning can usually be bypassed by clicking the “Resume” or “OK” button, or by disabling your ink level indicator. Here is a link on how to bypass the warning on Canon cartridges that may help:
http://swapink.com/Merchant5/merchant.mvc?Screen=caninst
Mar 24, 2010 | Canon BJC 6100 InkJet Printer
Printer says almost out of ink.
The low ink warning is normal if you are using remanufactured cartridges. Even if you are not, OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. The warning can usually be bypassed by clicking the “Resume” or “OK” button, or by disabling your ink level indicator. Here is a link to a tip on bypassing the warning on Lexmark printers as well:
http://swapink.com/Merchant5/merchant.mvc?Screen=lexinst
Mar 22, 2010 | Office Equipment & Supplies
Printer says out of ink, won't print
Greetings,
Try this In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
This isn't set level but it disable ink check. The LED warning still blink but no error code appear anymore.
Regards,
TechSup1
Apr 30, 2009 | HP Deskjet 5940 Photo InkJet Printer
Service error 5600 appeared when the printer stop
Dear budg,
Error code 5600 in S200 is No Print head Error indicator. In this case, the print head of the printer is faulty so that the printer cannot detect the print head. About the print out, please check if there is enough ink in ink tank to print. If there is enough ink to print, means this bad print out caused by the faulty print head. It seems that you to replace the print head.
Regards,
Dec 02, 2008 | Canon S200X Ink-Jet InkJet Printer
HP OfficeJet 4215 All-In-One
No, only when it indicates that it is out of ink, does it stop printing. It is warning you now, so that you can purchase more, and be ready when it does run out. If it will not print now, then there must be some other problem.
Dec 06, 2007 | HP OfficeJet 4215 All-In-One InkJet...
Lexmark X85 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
