Question about Archos 704 WiFi Digital Media Player
Archos 704 I have an Archos 704 and it has started to play up. The unit will start and gives me the Archos logo but them will not go on to the menu it simply restarts and gives me the logo again it does this over and over. Can you help
  • charredrob Feb 06, 2008
    have followed the instructions and had to format the harddrive, however know i get on the same white screen for recovery. i can now connect the unit to the pc but it asks me to install an update file, what ever that is can i find i ton the net somewhere. Sorry to be a problem but i am abit of a spastic at this kind of thing. Thanks for your help nd any thing else would be appreciated.
    Thanks dude my Archos is up and running you are a guru!!!!
    Brigadier General:
  • 6,966 Answers
Your post/description indicates a possible problem with the firmware. It would seem that the Archos 704 would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
Things you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Do a Systems Recovery by powering on and immediately press/hold the TV button till Recovery Mode is displayed. Follow on screen instruction of Forcing Touch Screen Calibration. You may need also to format the internal HD but that would mean you loose whatever data is inside.
If the above is not corrective, am afraid that your unit has been partially bricked. Some have reported serious hardware or firmware problems with the 704 that would require replacement by the manufacturer.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 05, 2008
  • Louie  Role
    Louie Role Feb 06, 2008
    Hi again,
    A more complete and better explained firmware update procedures are here.
    As otacon have posted, pls verify that you have the Wifi version and not the TV.
    Briefly, you have to download and save in your PC the a704wifi.aos file (there are 2 versions of the firmware; Archos 704 Wifi OS v 1.7.22
    - this is the latest firmware but it will not allow you to downgrade if something goes wrong and the old Archos 704 Wifi OS v 1.7.20. You need to determine which one is your current version by tapping the "Firmware Version" and decide if you want to install the old or the latest), connect your 704 to the PC, copy/paste (drag & drop) the said file to the Archos device listed in "My Computer" (you may have to overwrite the older copy), disconnect 704, proceed to System Settings, tap on "Update Firmware". Follow on screen instructions.
    Cheers.
  • Louie  Role
    You are more than welcome and am glad to be of assistance. Appreciate the rating too.
    President:
  • 1,944 Answers
Did you try power cycling the unit?
  • Damen Wong
    Damen Wong Feb 05, 2008
    You have the WIFI version...right? Not the TV version.
  • Damen Wong
    Damen Wong Feb 06, 2008
    I am glad your unit is up and running =)
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jul 24, 2009 | Archos 704 WiFi Digital Media Player
Archos 704 wont turn on or charge
First, start with the easy stuff - remove the battery and press the reset button - hold down for about 10 seconds. replace the battery, attach your AC adapter and attempt to start the player. If it still won't start, you may have a damaged DC-In connector OR the charge circuit may be bad - a TI Chip on your main board sometimes goes bad - it can be replaced. Also, if the battery is absolutely dead - no charge left at all, the player will not start even with an AC adapter
Jul 03, 2009 | Archos 704 WiFi Digital Media Player
Battery difference between archos 704 and 705 (wifi) ?
I use the same batteries in both units. The only difference is the colour of the back plate and the label on the inside. Clone and extended batteries are different backs anyway.
Nov 17, 2008 | Archos 605 WiFi Digital Media Player
Change my program in archos 704
You can copy files via USB to the 704 using media player in sync mode or drag and drop in windows explorer. Which mode you use depends on what mode the 704 is set.
Oct 26, 2008 | Archos 704 WiFi Digital Media Player
Archos 704 stopped working
A couple of things you can try:
  1. hard reset the 704 using the button under the battery right hand side;
  2. reformat the unit (but that would of course delete contents).
Just curious, did you try/did a firmware update recently? Additionally, the manual has some details on troubleshooting as well as Archos online support.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Jul 18, 2008 | Archos 704 WiFi Digital Media Player
Archos 704 wifi not starting up
If you enter recovery mode then connect to a computer, you can then use windows drive checker to verify the drive. If all is OK, copy firmware to the root then disconnect and reboot
Apr 09, 2008 | Archos 704 WiFi Digital Media Player
ARCHOS 704 WIFI
The video plugin you bought is so that you may watch Videos by transferring them from your computer. But what you are trying to do cannot be done because your archos browser does not come with flash so you cannot view videos in a website. Unfortunately it just cannot be done. I also have a 704 and was very disapointed to learn that I cannot watch videos from websites.
Dec 29, 2007 | Archos 704 WiFi Digital Media Player
Archos 704 Wifi - does not play AVI file until its full lentgh
I had the same issue.
The size of the AVI cannot exceed 1gb or the end of the movie will never play.
I had a movie that was 1,7gb. 2 hrs and 15 seconds.
The Archos recognized this as a 1.7gb file and 2:00:15 long.
As soon as the movie started, the time line bar at the bottom of the screen went from 2:00:15 to 1:10:25. Basically, it cut off the last 50 minutes of the movie.
I simply divide the movie into 1gb chunks.
I decrypt the DVD to the computer
Use Nero Recode to convert it to and MP4. Divide the movie into 1gb chunks and Maximize the Volume.
Use SUPER to convert it to an AVI / MPEG-4 / MP3.
Copy this to the Video folder of the Archos.
This is simply something that Archos does not want to admit is an issue. They want you to purchase the Cinema plugin.
Sep 28, 2007 | Archos 704 WiFi Digital Media Player
Archos 704 WiFi Digital Media Player Logo
212 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
