Sony KDS-50A2000 50 in. HDTV Television
Problem for Sony KDS-50A2000 50 in. HDTV Television
My tv is blinking red in the power indicator 4 times on my KDS-50A2000
By troy20 on Feb 05, 2008
It is as if the tv is still powered on with the red light blinking 4 times then it pauses then repeats. I press the power button to turn it on and it tries and the red light then startes to blink green for about 5 seconds then a click in the back of the tv and the red light comes back as before. I tried unpluging and pluging in other places but did not work. Help please!
Same Problem
Apr 19, 2009
-   Where are the three fans pls tell me -   Guest
Feb 03, 2009
-   Sony 35 in.
-   Guest
Oct 16, 2008
-   There is no picture and the screen is black, the power is on and the sound for the last channel I had on is playing. A red LAMP light is blinking. Do the lamp need to be replaced?-   guenther566
Sep 30, 2008
-   kds50a2000 sony tv wont power on and is blinking 4 times red over and over,very upset since the warranty is up and it looks like a $500 repair bill,i may just dump it,lol-   sarasotatiki
Aug 05, 2008
-   SAME PROBLEM!-   huntfamily2
Best Solution
posted on Jan 01, 2009
Very Helpful)
lapidot
Rank: Apprentice
Rating: 100%, 5 votes
I had the same problem. Red LED blinking 4 times. This error means that one of the fans is NOT spinning! To check.... unplug the tv.... turn the TV around to a well lighted area so that you can see the fans in the back... plug the TV in and turn it on. Watch for the fans in the back... and see if they are spinning. If not... that is the reason why the TV will not turn on! In my case, the fan next to the lamp was stuck for some reason. I removed the the cover of the TV from the back... and cleaned the fan, made sure all connectors to it were properly connected... and viola! The TV is perfect again! Enjoy!
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Aug 23, 2009
Very Helpful)
Ant B
Rank: Apprentice
Rating: 100%, 3 votes
Hi - had the 4 blink (red) LED problem. The green LED would flick nine times and then go into this cycle of 4 blinks on red. No screen / picture just volume. Sony were not much help and the authoriszed service stores wanted $150 just to come out and assess. So here's what I did (taking the lead from best solution above).
I took the back off and gently vacuumed the rear fan. I checked the power lead connector too by unclipping it from the circuit board and re-attaching it. (back right hand side as you view from the rear) I tried to power up but at that stage, no luck.
I then took the rear lamp out and again vacuumed the dust that had accumultated in that compartment. I re-inserted the bulb, put the bulb cover door back on (essential as it would not power up for me without it) and hey presto - my beloved TV is back.
It seems to me that these things are hyper-sensitive to dust and that with a bit of gentle maintenance and cleaning some of these problems can get resolved.
I'm sure a repair ship would have done the same as I did hear (20 minute job) and would have slapped me with a several hundred dollar bill.
Good luck.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Feb 20, 2009
Very Helpful)
arnelgm
Rank: Apprentice
Rating: 100%, 1 votes
blinks 4 could be a problem with one of the three fans - arnel
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jan 13, 2009
Very Helpful)
usdurrs
Rank: Apprentice
Rating: 100%, 2 votes
I had the same problem after having the tv for two years - service plan ran out three days ago....go figure! I followed solution 1 from lapidot and wouldn't ya know...it worked!!! The fans were very dusty and after a good cleaning....problem solved! Thank you lapidot for saving me hundreds of dollars!! :)
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Mar 21, 2008
Somewhat Helpful)
tvwonderland
Rank: Apprentice
Rating: 75%, 2 votes
What the solution is getting at is that a chip in the TV is bad and only service can fix it. It is not something you can fix. Call a repair person out.
Sorry.
Was this helpful?
Yes
No
Solution #6
posted on Feb 06, 2008
Somewhat Helpful)
Slinteriors
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 89%, 3847 votes
FOUR Blinks---No Vert. Deflection (V STOP) Check IC1509, Q1505
Was this helpful?
Yes
No
Solution #7
posted on Jan 16, 2009
Not Rated)
judygood46
Rank: Master
Rating: 86%, 4 votes
The STANDBY light is flashing on the television and there is no picture or sound. Solution
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Was this helpful?
Yes
No
Solution #8
posted on Oct 01, 2008
Not Rated)
sarasotatiki
Rank: Apprentice
Rating: 0%, 0 votes
kds50a2000 blinking 4 times,i replaced all three fans on my tv and all is well now
Was this helpful?
Yes
No
Solution #9
posted on Jun 27, 2008
Not Rated)
adamr73
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem with this TV and was told by Best Buy service and Sony service that the four blinks is the service code for the main exhaust fan malfunction. They are coming back this week to replace the fan.
Was this helpful?
Yes
No
Popular Solutions for Sony KDS-50A2000 50 in. HDTV
Questions and Unsolved Problems for Sony KDS-50A2000 50 in. HDTV
Do you recommend Sony KDS-50A2000 50 in. HDTV Television?
Answer
Answer
Our SONY KDS-50A2000 rear-projection television recently developed a green tint to all pictures. ... (More)
Answer
sony rear projection - error comes up when tv is turned on - says ventilation is blocked, tv will... (More)
Answer
pictur is green 70% .bulb is new.black -wite pictur goes to green
Answer
Power Light continuously blinks with no picture or sound. The Ballast and S2 Board have been... (More)
Answer
picture is on the green side and I tried to adjust it in the menu but no help
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 31, 2008
Same problem. Purchased TV April 2007. Great picture.
However, 13 months later am experiencing identical frustration. Warranty is only one year. Have been a Sony loyal customer for decades - as such am extremely surprised. Called Sony Support number listed on TV. They indicated that it is a service issue and "will work with me to resolve".
Am extremely concerned that this may be a design flaw that will keep reoccurring (read "endless money pit"). Am presently awaiting on the service technician to tell me what wrong.
It also happened about a month ago - I unplugged TV and it began working again. But, this time it appears dead. Did not work after being unplugged for several hours.
Comment by Guest, posted on Mar 24, 2008
same issue. appeared within a few weeks of warranty expiration. i've reseated and then replaced the bulb, each time getting a little more life out of the set before problem reappears. checked the fan to make sure cooling is functional. the only authorized service center in town estimates $400 to fix it plus $125 to transport it. first time in 20 years a sony product has taken a dump on me (so i passed on the extended warranty) but there won't be many of these 500 buck repair trips before this thing winds up in the dumpster.
Comment by tvwonderland, posted on Mar 21, 2008
My TV also started blinking red in the power indicator 4 times on my KDS-50A2000. I turned it off, unplugged it and still same problem. The TV will not power up. I have had my TV since November 2006 and it has been great.
Is this an issue with this TV?
Comment by Obestu, posted on Mar 12, 2008
I have the exact same problem. It is as if the tv is still powered on with the red light blinking 4 times then it pauses then repeats. I press the power button to turn it on and it tries and the red light then startes to blink green for about 5 seconds then a click in the back of the tv and the red light comes back as before. I tried unpluging and pluging in other places but did not work. I don't understand the one and only posted solution.
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Beverly Hills, CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
