Toshiba DVD player
DVD player says "incorrect disk" and will not play.
  • 2 more comments
  • maryhorn Feb 06, 2008
    Yes, it occured with three different discs. By the way, it also makes a straining noise before it says incorrect disc.
  • maryhorn Feb 07, 2008
    How come no reply to maryhorn message of 2-05-08 ?
  • maryhorn Feb 08, 2008
    I'm here. I'm using discs that come from Netflex and one store bought one. I'm going today to get a disc cleaner. But, other than that???? Maryhorn
    to otacon: Yes it read a "music" disc just fine. Should I forget about the disc cleaner under these circumstances? Thanx for your help. maryhorn
  • 871 Answers
Hi there
"incorrect disk" means that the cd/dvd inserted is not the correct format or the cd/dvd inserted has a format that the player does not support. Dvd players has specific formats which they could read and up until now, there are a lot of upgrades that dvd players can read.
What you need to do is check if the cd/dvd you inserted is a supported format for your player. If it is, you might want to clean your player with a lens cleaner.
hope this helps.
Posted on Feb 05, 2008
    President:
  • 1,944 Answers
Does this happen with all discs? What disc are you inserting that gives this error? DVD?
  • 1 more comment
  • Damen Wong
    Damen Wong Feb 07, 2008
    I am still with you. The straining noise is the just the unit trying to read the disc. Say, are you using original store bought discs?
  • Damen Wong
    Damen Wong Feb 08, 2008
    You there?
  • Damen Wong
    The lens cleaner could solve your problem since dust on the lens can cause it to not be able to read discs. Can the unit read regular CD's (not DVD's)?
Incorrect region for panasonic dvd player
The player is set to a fixed region relevant to the country you are in for play back of DVD disks and the disk you are trying to play is not compatible with the country you are in! You need a multi region player or to have your current player unlocked to be multi region! Which country are you in?
Oct 02, 2014 | Panasonic Televison & Video
The dvd player says "incorrect
The DVD player is region locked and will only play DVDs from a particular region. The cheap DVDs are probably region 0 and so will work on any DVD player. You can scour the internet for a code hack to change the region (I've had a quick look and not found anything).
Feb 20, 2011 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Program says dvd+r incompatible with toshiba dvd player
Some DVD players will read 'DVD-R' ("minus-R") disks.
Some DVD players will read 'DVD+R' ("minus+R") disks.
Some DVD players will read "both" types of disks.
So, if you're burning onto a DVD+R disk, you won't be able to "play" the disk on your Toshiba DVD-player.
Instead, buy "blank" DVD-R disks, and write on them.
Apr 05, 2010 | Computers & Internet
Put dvd in and it says incorrect disk
http://www.fixya.com/support/p203786-toshiba_sd_v392_dvd_player_vcr_combo/manual-5746ve
If you go to the above manual you will find many discs which your dvd can`t play.Check to see if this is the problem.
Oct 20, 2009 | Toshiba SD-V392 DVD Player/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Dec 03, 2007 | Toshiba D-VR4 DVD Recorder/VCR
DVD player - ERR
error in any disk i put in!!!!!!!!!
Nov 14, 2007 | Toshiba SD-V280 DVD Player/VCR
I find when my unit gives that same message, if I unplug it for a few hours, the memory resets itself. You may have tried this already, but it does work with my machine. tcast at yahoo.com
Jan 28, 2007 | Toshiba DR4 DVD Recorder
Televison & Video Logo
281 people viewed this question
Top Televison & Video Experts
