Question about Lexmark X1150 All-In-One InkJet Printer
Printer settings I would like to set my printer at "Quick Print" for all future printing. is this possible?
  • 113 Answers
Go to the control panel and select printers
Install your printer again but give it the name "quick print"
Right click the printer and go to properties.
Modify the printer to quick print and save it.
Then set it as your default printer.
When ever you want to print regularly chose the other printer.
Posted on Mar 03, 2008
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
How do i get the best/profesional look from my printer
You can adjust the print mode from quick print to normal mode or best mode to achieve the print quality you prefer. Click the Properties button on any Windows print dialog. On Mac you can select Quick Print in the Print Settings pane in any expanded print dialog.
Jul 12, 2011 | Lexmark X3650 Printer
How do I print a document from my files ? I hit the print button. but n othing happens. I need to print newsletters from my e-mail. e-mail is wmmurf @ att.net Thanks Martha M.
dear Martha
if you need to print your document directly by pressing quick print button then you have to set your printer as the "default printer". to do this you have to go to Control Panel > Printers and Faxes and then right click on the printer you want to set and then click "Set as Default Printer" your problem will be solved.
Thanks
Gagan
Mar 24, 2011 | Office Equipment & Supplies
I have a HPC7280 all in one. it is asking to insert a memory card for copies. why? how do i get around that.
It sounds to me like you have selected an option to print directly from a memory card at one time. Here are excerpts from the user manual for your machine to change printer settings:
Change the print settings
You can customize the print settings of the HP All-in-One to handle nearly any print
task.
Windows users
Before you change print settings, you should decide if you want to change the settings
for the current print job only, or if you want to make the settings the defaults for all
future print jobs. How you display print settings depends on whether or not you want
to apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Director, click Settings, point to Print Settings, and then click Printer
Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
I believe that this should help you get around your issue. Here is a link to the entire user manual for future reference.
http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf
Dec 22, 2010 | HP PSC 1610 All-In-One InkJet Printer
I want to print onto christmas cards, how can I set up my HP photosmart 2610 to do this
To apply the change to all future print jobs or just to the current print job.
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Settings.
Dec 03, 2010 | HP Office Equipment & Supplies
Cannot change/ save two default settings on X6570 Lexmark printer
you can go to printers and faxes (XP) or printers (vista) in control panel Right click on the printer and click on properties. Go to advanced tab and click on printing defaults. It will pop up the printer printing preferences. choose the desired setting. To disable 2-sided printing, go to advanced tab in the preferences window and turn off the feature. Click ok to save all settings. Go back to general tab and click on printing preferences and set desired settings if there is a need. Click ok to save settings. Then, for all changes to take effect, click ok button on the lexmark 6500 series properties window. Try to print again. Hope this helps.
Feb 17, 2010 | Lexmark X6570 InkJet Printer
Color Cartridge out of ink - override/print in grayscale?
Printer will not print if any color is out. Just won't. They are set up like that.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
May 28, 2017 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C7280 All in One Printer. I am trying to print on new check paper, but it just keeps running it through and then prints on the regular white paper. Any quick fixes?
Check the preferences setting in your Printer Dialogue box (the pop-up that comes up when you attempt to print... the paper settings may be set to standard, which you can modify...
A quick-fix is also to simply print to plain paper, place the newly-printed form in the scanner, and press "copy" on the printer itself (the physical button, not from Windows), with the check paper loaded (place in just one sheet, as not to waste ink)
Hope this helps!
-- RT
Sep 03, 2009 | HP Photosmart C7280 Laser Printer
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
