FixYa.com
Tags:
Panasonic CT-36D32 36
High pich whine from CT-36D32 36" TV (by 2 users)
posted by jdosk on Feb 05, 2008
CT-36D32 36" TV This is my T.V. I moved it, watched the super bowl and moved it back. One city block in an Astro with good suspension and no bumps. I took it easy. I pressed power on the remote and got a high pitch whining tone constant from the lower back left of the tv. No degauss no screen flicker no Sound nothing but That noise. I can unplug it and the releay drops out and the noise goes away. Plug it in, I hear the relay engage then a halfway degauss. Not even a flicker in the screen in the dark of the night... How wird is this???? jdosk@bellsouth.net
Comment by jdosk, posted on Feb 07, 2008
I have narrowed the noise down to the open coil transformer looking thing that sits virtical to the front of the board bang in the middle. Front being toward the manual switches. This is the only coil that sits upright and the coils are wraped horizontaly. I assume that this is some sort of step up transformer. I sure don't know what is causing the osolations like that. ???? The Hi voltage Trasistor is not geting warm that is in close proximity of it.
Comment by jdosk, posted on Feb 16, 2008
Got the meter, Don't really know whitch is the fly back. I do know what transformer is osolating in the HOT part of the main board. What could be shorted? I have found new board and snap on part that is part of the HOT bout 400 bucks. Would that fixit?
Comment by jdosk, posted on Mar 10, 2008
What would it look like? I have soldered all the joints that looked bad. From what I read you are saying That the transitor is bad? not sure what to snach off the board and test. I know by the well marking of the board, which is the HOT area of the board... I do see a large Hi voltage looking darlington that has 4 legs on it. Could that be it...?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 06, 2008
I have the same problem with mine. I called sears service and they told me that it would cost 600 to 700 to fix, I then had to pay a 100.00 service call. I asked what caused this and the tech said that dust over the board prevented it from cooling down causing the problem. I have had this tv for just 6 years and it sure should have lasted longer that this, heck I still have tvs 20 + years old that still work. If any one can help with this repair please let me know. I refuse to just toss it into the trash can
brmcojim@aol.com
Best Solution
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
jdosk-the high pitch noise you hear is generally from the horizontal output being shorted,the horizontal output is usually near the flyback transformer,get a digital multimeter to checkthis part.Let me know I'll try to help. cooltek Feb.16/08
Rating Locked! (?) jdosk has rated this solution as Helpful
Solution #2
Helpful (85)
Terryfic
Rank:Guru Guru
Rating: 87%, 1320 votes
Bad solder connects in horiz driver circuit lead to shorted horiz output xistor....do.not try generic....won't hold...........T.
Can you Help with these Standard Televisions problems?
Panasonic CT-36D32 36" TV
TV goes on and off...
The panasonic tv just started... Answer This...
Please Help !!!!!!!!!!!!!!!!!!!
I have a Panasonic CT-32d32... Answer This...
27" Panasonic TV 1993...
I have lost picture ,Black... Answer This...
HELPPPPPPPPPPPPPPPP!
My Panasonic CT-32d-32f tv has... Answer This...
3D will not turn off
Have Panasonic TAU 34"... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
