Question about Lexmark X1150 All-In-One InkJet Printer
Scanner Printing is fine. When I use the scanning facility the page comes out with the words etc. O.K but the page is dark and inky!!
  • dougbromham Feb 06, 2008
    Thank you for help. Still adjusting to get best results but deffinately going in the right direction. would never have solved it by myself. Thanks again
    Genius:
  • 3,587 Answers
That's a resolution settings issue on the scanner software. Open up the scan manager, and set the resolution at fine or less, not superfine(which works for color photos, etc.)
Posted on Feb 06, 2008
  • Patrick Michaels
    Patrick Michaels Feb 06, 2008
    glad to hear it friend..glad to hear it. this is an inexact science, as you will most likely find out.
  • Patrick Michaels
    Patrick Michaels Feb 10, 2008
    Thanks for the opportunity to assist with your technical challenges.
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
When trying to print, message comes up saying printer needs aligned. It will only print the aligned page, and the printing on it is fine. Printer will print from the internet, but not from Microsoft...
Usually, the second part of the "alignment" process is to put the printed page into the scanner,
and then to scan the page -- the Lexmark will compare the "actual" printed-page with the "optimal" settings, and will adjust the printer to "align" the heads. Have you done this part?
> will not print ... from Microsoft Word
What happens? What does not happen? Did you use setup in Word to choose your printer as the "default" printer?
Nov 12, 2010 | Lexmark X2500 All-In-One Printer
I've been scanning in drawings and the drawings each have some words at the bottom of the page. When I scan it, only the words appear to be recognized but not the drawing. It was working fine before, why...
may be you have written the words in darker ink and drawing might have been in pencil! scanner usually recognises dark areas and adjusts the picture based on it! make sure you darken the drawing as much as those words!
Oct 16, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
What driver or software is needed to install the HP2355 scanner?
You can't scan to word unless you have OCR software running. Word is for text and without OCR it is only a picture or image and not text. It's not cheap but you need to shop around for something like Adobe with OCR to convert to text.
Jan 29, 2010 | HP PSC 2355 All-In-One InkJet Printer
Pages printing very dark
check your printer scanner. and replace it
May 21, 2009 | Brother MFC-9440CN Laser Printer
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
HP PSC 2355 all-in-one scanning problem
hi shaundoyle -
first, I wanted to point you to HP's general support page for your model:
http://h10025.www1.hp.com/ewfrf/wc/product?product=422000&lc=en&cc=us&dlc=en&lang=en&cc=us
here is another link, this one to a doc for connecting to more than one HP product using a Mac:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpm01356&dlc=en&product=422000
here's a link to a doc about the scanning stopping:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00803473&dlc=en&product=422000
and yet another link, this one for probs printing through 'classic' applications:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00035422&dlc=en&product=422000
it sounds like one piece of software overwrote another, or your two pieces of hardware are fighting each other for your Mac's attention. hope this helps a little.
-JW50
Oct 28, 2008 | HP PSC 2355 All-In-One InkJet Printer
Black Images Only
My scanner doesn'nt work... it's too dark and no lights when i started
Aug 13, 2008 | HP PSC 1315 All-In-One InkJet Printer
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Lexmark X1150 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
