Question about Toshiba Satellite A25-S2792 Notebook
SD card slot problem
I insert a SD card memory on my slot in my laptop, and it doesn't do anything. Why does this happen???
  • 1 more comment
  • yarita Feb 05, 2008
    4gb... does the HC matters?
  • Anonymous Apr 12, 2008
    I have a toshiba satellite a215-s7472. The built in card reader will recognize that I have put a memory stick in and brings up a new drive in the computer. but it says that I have not put a disk in the drive. Is there a fix for this? The card reads fine on my desktop..
  • Alexander Selby
    Alexander Selby May 11, 2010
    what size and type of SD card is it. NOTE: some SD cards have an HC at the bottom of the SD Logo!!!!
    Sergeant:
    Champion:
  • 317 Answers
Yes, these HC cards require a different reader, than traditional SD cards. The builtin one on the laptop probably doesn't support them, since any SD card above 2gb is technically considered an HC SD card. so my advice is to go to a cheap computer parts supplier, and see if they have a reader that will work for HC SD Cards.
DAMN THE MAKERS OF FLASH MEMORY FOR BEING SO COMPLEX!!!!
Posted on Feb 05, 2008
How to insert sd card from my mobile to laptop
You probably need a USB memory card reader that can read SD cards. I do not any brand of laptop that has an SD card slot built-in. You can probably find printers with card slots.
Dec 15, 2014 | Cell Phones
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Why wont my computer recognize my sandisk memory card anymore
Sometimes it happens that your slot doesn't work you can use a another option like Olympus LS-10 digital recorder as a card reader for accessing the data. Insert the SD card in your LS-10 digital recorder then connect the recorder to the computer with a USB cord then it will show you two options for the onboard storage inherent and one for the SD-Card. Select first photoshop elements to read the card and then Windows Live photo Gallery to view and copy your photos.
If the Information helped you out then please give me some ratings. Thanks
Jun 01, 2012 | Sandisk 4 GB Standard SDHC Card with Rezo...
Where can I insert my mini sandisk memorycard into my toshiba laptop? I see no slots for it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
Dec 06, 2010 | SanDisk 2GB microSD Memory Card
Can i insert this type of memory card into the slot into the computer directly? it says on my laptop that sd, xd and M (symbol for pro duo? )can be inserted. But when i try to insert it, it doesn't appear...
it is advisable to buy a AIO (All in one) card reader, you can use this to many different type of memory card, the built in slot for memory card in your laptop sometimes only suite to a single type or model (ex. SD slot..MMC Slot etc.)
in your case your memory card is not fit to it, don't force it you might damaged your card
Nov 01, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
How to insert SD memory card into card rader in laptop computer
I would like to inform you that Acer's laptop doesn't support all kinds SD memory cards available in local market. Its not compatible with all physical dimensions of various memory card companies. So in that case you need to use EXTERNAL Memory card reader which is attachable to USB ports.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 29, 2009 | Computers & Internet
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
This is most generally a driver issue. Go to HP's support site and download the proper driver. It's more than likely a utilities driver.
Jul 03, 2008 | HP Compaq nc6000 Notebook
Memory Card
Hi Asunten,
I think ur memory card slot have the problem. It is a physical problem n u must contact mobile technician.
And rina_444,
The memory card for NOKIA and sonyericsson are different.
MMC for NOKIA is micro SD card, or mini SD but for sony ericsson, it accepts m2 card.
Send me a feedback and rate my solution too.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
May 09, 2008 | Nokia 3250 Cellular Phone
Toshiba Satellite A25-S2792 Notebook Logo
649 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
