Question about Toshiba TP61H60 61" Rear Projection Television
"noisy" convergence I used to be a TV repairman back in the days of vacuum tubes. I can only describe this problem as the red convergence goes bad in a random flickering fashion after the set has been on for some time. How is convergence accomplished in this tv? Is there a module that can be replaced?
  • 2 more comments
  • Douglas Mader Feb 06, 2008
    Thanks, I suspected as much. Are these parts readily available? If so where do you suggest? Are these located on the main circuit board? Can you tell me where? Are board layouts and schematics available anywhere?
    Thanks. I presume these are in sockets? How can they be identified or located? Are any other associated circuit parts likely to need replacement?
  • Douglas Mader Feb 07, 2008
    I have been reading other DIY boards and some refer to STK392-150, 160, 180, IC's that are direct replacements for the original 110, 110T but run cooler. Do you know if Toshiba recommends this change?
    partstore lists the STK392-110T for $40. You think that is a good one?
  • 2,336 Answers
The output STK ICs in the convergence circuit need to be replace, maybe a few associated low value resistors, fuse resistors etc.
These IC's are mounted on a heatsink, clean the are and apply thermal compound before installing the new ones.
Let me know if you need any more assistance.
Posted on Feb 05, 2008
    Genius:
  • 3,422 Answers
Convergence is a very common problem these days.The only solution is to replace the two STK Ic's on the board and your problem will be solved.
You can get the parts at www.ptscorp.com or www.partstore.com
Hope ur problem gets solve soon..
Goodluck,
Please don't forget to rate me as fixya..
  • 4 more comments
  • Priya darshan Feb 05, 2008
    If u have any other problems please be free to ask me..
  • Priya darshan Feb 06, 2008
    Hi you can get the ic's at www.partstore.com or www.ptscorp.com.Make sure u have the part number..
    Goodluck once again,
    No u don't need any other replacements
    if replacing this component don't use cheap ones, there are a lot of
    inferior components on the market, you should pay approx $25 not $6 for
    them.
    You could just as easierly have a simple bad solder joint that needs to be resoldered.
  • Priya darshan Feb 07, 2008
    If you are satisfied with my solution then please don't forget to rate me as fixya..
    Yes it is a goodone and if you think you can solder it by ur self then please go ahead..
    Cuz toshiba will charge lots bucks for this it will be anything between $200-$300.And if u feel it u can't do it then call toshiba..
    Goodluck once again and please don't forget to rate me as fixya..
My panasonic tv has started too have very bad picture problems colors of red blue green going thru the screen
Replace convergence ICs in tv by local tv repairman to fix tv problem as picture become very bad due to convergence chips failure.
Oct 13, 2010 | Panasonic Televison & Video
I have a Sony KP-65WS500 from 10/2002. There are thin red arcing lines across the screen when the scene is dark or black.
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Sony KP-65WS500 65" Rear Projection...
Will not converge
hello, the convergence ic's have gone bad in your tv . and sometimes they fail because of a 50 mfd @ 50v capacitor by each ic goes bad. if you have the skill at soldiering and desoldiering you may try repairing it yourself otherwise leave it to a qualified repairman. thanks .....techman...580-243-8025
Apr 01, 2010 | Apex Digital GB43HD09 43" Rear Projection...
Thew picture is double vision and orange and green. Is this the picture tube?
The red and blue convergence ICs are bad. Probably only the red one is bad, but you should change both to be sure the other doesn't go out the following week. Go to tritronicsinc.com for the the replacement chips. The chips should be installed by someone with soldering experience as they have about 20 pins each.
Oct 01, 2008 | Hitachi Televison & Video
Auto focus problem
The auto focus is not actually focusing the tv. When it is running it is adjusting the convergence. Most likely the repairman that replaced your tuner didn't plug the sensor wires back in. I would call him back out and have him hook it back up.
There should be a convergence menu in the tv. Use the samsung remote and go into the menu and look for convergence.
Sep 11, 2008 | Samsung HCM553W 55" Rear Projection...
Red sideways hourglass
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
Model 9P6040C104
  • Screen looks 3D
Jun 28, 2008 | Philips 9P6444C 64" Rear Projection...
Sony kp41s3u - blue screen
Convergence amp ic bad or loose connection on ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Feb 26, 2008 | Televison & Video
Toshiba 50H81 manual convergence
are you sure it's yoke? these are know for bad convergence amp ic's
other wise it's a screw and glue holding the yoke in place loose the screw and try to break the glue with out breaking the plastic on the yoke, the other thing you can do is adjust the magnets which have tabs on the yoke. i would mark the position's of everything on the tube with a sharpie so you can get it back to start.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 50H81 50" Rear Projection...
SONY KP-43T75 HAS ISSUES
  • Screen looks 3D
Sep 21, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Toshiba TP61H60 61" Rear Projection Television Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
