Question about Zebra Z4Mplus Label Printer
Ribbon install how to install ribbon
  • Uzzal Feb 18, 2008
    How to Install a Ribbon & Label on Zebra Z4Mplus Label Printer?
  • cschneider Mar 30, 2009
    I need to change the ribbon too- but that description doesn't help me at all!
    Help!
    How do I get the old ribbon off the spool?
    Champion:
  • 207 Answers
Open the black cover of your ribbon storage..remove the soiled ribbon. locate the origin of the ribbon( do not pull the ribbon hard as if you don't mess the arrangement) follow the pattern that has an outer pathway located beside to your original hook of the ribbon then pull the ribbon out gently (just follow the arrows that is indicated on the case)
Posted on Feb 05, 2008
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
CORRECTION RIBBON
The correction ribbon is installed on a separate mechanism on a typewriter. If you look between the regular ribbon guide and the card holder you should see the correction ribbon guides on the right and left hand side of the card holder. the spool holders will be to the right and left of the correct ribbon guides. This is true only if the typewriter has a correction mechanism installed. Some machines do not have a correction mechanism. Correction is achieved by using a correction tab which is held by hand, in front of the letter to be removed, or white out. Some correction tapes attach to the bottom of the print ribbon.
Nov 06, 2013 | Swintec Office Equipment & Supplies
Evolis pebble 4 shows the end of ribbon light...
Not card, not ribbon, not cleaning, not driver setting.
Does your black ribbon roll and never stops?
Sep 10, 2012 | Evolis PEBBLE 4 Led Card Printer
I just installed a new ribbon on my olympia deluxe and the ribbon keeps getting loose. Could that be because I installed the ribbon wrong? What could be the problem?
You probanly installed it wrong. Most T/W's spooled ribbons wind to the outside of the spool, however there were a few that wind to the inside. Withe the ribbon off type & watch the spool mech. install the ribbon so that it will wind onto the spool.
DickyO
Nov 09, 2010 | Olympia Office Equipment & Supplies
This machine gets used just a few times a year for straight typing. I was asked to replace the ribbon as the letters weren't appearing on the paper when the keys were pressed. No one knew when the last...
I'll assume this is an ibm ww. Just below the ribbon deck on the right is the ribbon feed motor try na little WD40 on the upper and lower bearings they do gum up also be sure the ribbon motor is plugged in.
DickyO
Oct 06, 2009 | IBM Office Equipment & Supplies
How do I replace the ribbon on an Underwood typewriter?
Really? An Underwood typewriter?
First, do you have a replacement ribbon that is not dried out? Does the ribbon come on one spool or two?
If the typewriter already has a ribbon installed, it is a simple matter of noting the path the current ribbon follows, and which way the ribbon winds onto the spools. Then install the new ribbon following exactly the same threading path. If there is not already a ribbon installed, then it is a little more complicated, and it will depend on your spatial relationship visualization skills.
1. Type a few letters on the typewriter, and take note of which way the spools turn.
2. Mount the two new spools containing the new ribbon so that the full spool will supply (unwind), and the empty spool will take-up (wind) the ribbon.
3. Thread the ribbon through all of the guides in the threading path - there are probably about 6-8 guides that the ribbon has to go through. The most important guides are the ones that carry the ribbon in front of the typeface elements as they strike the paper. But equally important are the guides that monitor the tension of the ribbon - they will cause the spool advance mechanism to reverse the ribbon take-up direction when the ribbon reaches the end of travel.
Sep 22, 2009 | Office Equipment & Supplies
My printer displays ribbon error. but there is ribbon inside
you can change which ribbon type is installed in the printing preferences of the printer driver.
make sure you have the right ribbon type selected.
CYMTKO vs. CYMTO, etc.
There is also a button that will auto detect the ribbon right underneath the pulldown menu.
May 26, 2009 | Fargo DTC550 Thermal Card Printer
How do you install a new ribbon?
I assume this is a wheelwriter. If so push the blue lever on the rt. side of the ribbon to the rear and lift the ribbon and lift off out of the machine, seperate the ribbon and L/O. Attach L/O to the new ribbon, insert the two "feet" on the ribbon casstte into the slots on the ribbon deck and snap it into place.
DickyO
Sep 30, 2008 | Lexmark Wheelwriter 15 Series II...
Correction ribbon
make it sure that the correcting ribbon correct insert to the guide of the ribbon push it then you feel lock , test correcting not jumping ribbon case , then ok.
Dec 11, 2007 | Brother GX-6750 Typewriter
Zebra Z4Mplus Label Printer Logo
737 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
