Question about Garmin StreetPilot c340 GPS Receiver
Gps not turning on
My garman, streetpilot c340 will not turn on. I have pushed the reset button and plugged it in . No result.
  • 5 more comments
  • Anonymous Feb 18, 2008
    My garmin shuts down immediatly after I switch it on.
  • 1501 Feb 23, 2008
    My garmin will not charge with the usb cable--i do not even get a screen or battery charging display on the screen--it seems like it is just dead all together but I only got it 3 yrs ago?
  • Dinesk Feb 24, 2008
    My garman, streetpilot c340 will not geeting on. I tried to recharge still no effect.
  • Anonymous Feb 25, 2008
    What luck. I removed the faceplate. Pressed the reset button. All worked fine. It's charging now. I just hope I didn't loose my own points of interests.
  • Dinesk May 11, 2010
    1st recharge it and then try to switch on
  • 1501 May 11, 2010
    if I have the garmin plug into the computer shouldn't i get something on the screen?
  • kiij May 11, 2010
    Does it need internal battery replacement.
  • 504 Answers
Have you tried charging it using the computer? This sometimes helps.
Posted on Feb 07, 2008
Garmin c340 will not turn off and I cannot see a reset hole.
Your unit has a reset button under the faceplate. There is an indentation under the top of the faceplate. Insert your fingernail and gently pry it forward. Pull the whole faceplate off, and you will see the reset button on the bottom right of the unit. I hope this helps.
Jul 20, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 frozen in on position does not turn off when power is pushed stuck on arrival time
Look on the back or on the side someplace, what you are looking for is a small hole, just a little bigger then a paperclip. This should be the reset button, hit that with said paperclip and then allow the system to reboot. This should clear up the problem.
Mar 12, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Jun 03, 2009 | Garmin StreetPilot c340 GPS Receiver
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Jan 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Dead Garmin StreetPilot c340
The battery usually has a small charge when arriving from the factory, but it can die before it is received. You should charge this by plugging it into the car or the computer.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
292 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
