Question about Lexmark X5470 All-In-One InkJet Printer
Fax i recently bought 2 lexmark 5300 mainly to fax and copy . the box said you could fax without hooking up to computer just to the phone line. my problem is there is no way for me to try and test this and i wanted to give one to my mom as to being able to fax her papers she needs. is there any such thing as test faxing and also i cant seem to set the day and time thank you
Go to this link. http://www.revenue.state.pa.us/revenue/cwp/view.asp?a=190&q=209835
It's PA state tax forms thet you can have fax'ed to you for free. Good way to test receiving faxes.
Posted on Feb 07, 2008
Attempting to FAX...ErrorCode OxAF8D...cannot find this code in manual.
Where do you initiate faxing - from your computer or using the printer operator panel?
Try the following steps to determine what is causing this problem:
  1. Disconnect the printer from the phone line from the wall.
  2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  3. When the printer turns on, try to make a copy or print from your computer to verify that the printer is working normally without connecting to the fax line.
  4. If copying or printing from computer is working properly, then connect it to the fax line.
  5. Try to send a fax from the printer operator panel.
  6. Try to send a fax from your computer. If error appears, try to update your printer software by inserting the printer's installation disc into your computer hard drive.
I hope this helps.Please keep me posted.
Nov 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
There is a fax failure when receiving a fax. The activity report said REMOTE FAX ERROR. What have I not set correctly? We have never set up the fax before so have no previous history. We are using a...
If you have specifically requested a "double" ring pattern for your fax from Telus, then you have the right setting, otherwise, select the Any ring pattern to avoid fax transmission failure.
For more troubleshooting steps, please refer to this Lexmark article about Main Contributing Factors to a Fax Receive Failure on Inkjet All-In-Ones.
Sep 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I was given a Lexmark x4270 and all I want to do is use it as a fax machine. What do I need to do? Do I still have to hook it up to my computer or just the phone line?
You will just plug the phone line into the all-in-one. No need to connect it to your computer if your not going to use it to print. Once plugged into a phone line, use just like a fax machine.
Mar 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
I bought this x1240 second hand. it prints and copies well. how do i get it to fax
You will need to connect your Lexmark X1240 printer to a computer that is hooked up to a fax modem. Open the top cover. Place your document you want to fax facedown on the glass. Make sure the upper left corner of the front of the item aligns with the arrow. Close the top cover. Open the Lexmark All-In-One Center. From the Creative Tasks section of the All-In-One Main Page, click Fax an image. Follow the instructions on the computer screen. I hope this information has been helpful. Thanks.
Dec 28, 2010 | Lexmark X1240 All-In-One InkJet Printer
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
Note: Press the keypad numbers to use an automated answering system.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
I lost my fax instructions for phone hook up for my Lexmark X5340
Here you go M8!
http://www.lexmark.com/publications/pdfs/2007/5300/en.html
THere you will find the users manual. Download it and you will be fine.
Good luck to you
Please take a moment and rate my answer
Nic
Feb 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
CAN'T GET FAX WORKING.
If it's answering on your main number, then you are not plugged into the fax jack. You should have a separate phone jack for fax. If you have internet phone there should be a second jack on the back of your phone box. You can test that you have a functioning second line by plugging the fax into it and using the fax unit to dial your home number.
Jan 05, 2009 | Dell 926 All-In-One InkJet Printer
I have a Lexmark 5150 all in one.I recently hooked up to broadband.I cannot use the fax now. It says no communciation. How do I get my fax machine to work again? The printer and scanner work fine.Do I have...
Hi Brenda,
Your All In One wants a phone line hooked directly to it. It won't fax without a "POTS" line directly hooked to it. POTS stands for "Plain Old Telephone Service" which is the line with good old dial tone on it.
Dec 17, 2008 | Lexmark Computers & Internet
Lost manual
There is no much to hook up, you hook up the RJ11 phone connector at the back of the printer to the phone line.
Install printer software onto the computer.
Then connect printer to computer using USB cable.
See here , there is user guide for all x7300 series:
User's Guide
see also
Lexmark X7350 Top 20 Questions
Here also notes on how to set up fax
Lexmark X7350 - fax problem
Sep 08, 2008 | Lexmark X7350 All-In-One InkJet Printer
Installed Lexmark 1240 but when I try to set up fax it says no modem found
Yes, This assumes that you are hooking the printer upto a 56k/Fax modem on the Computer, Which the Printer already has itself, What you will want to do, Is hook a Phone line upto the the Printer in the appropriate slot, and dont worry about setting the Fax feature up on your Computer, Just Worry about the Scanner, printer. For the Fax Feature, Dial the number on the Printer and It should work without Ever touching the Computer
Jul 11, 2008 | Computers & Internet
Lexmark X5470 All-In-One InkJet Printer Logo
236 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
