Scanner on ir2016i
How do you get the scanner on the ir2016 to work?
It doesn't have an option to switch the scanner online
Which port do I use for the printer when I'm using
the ethernet port? Is it com's or lpt?
Derry
  • 983 Answers
For printer it s lpt port....
Posted on Feb 05, 2008
HP LJ 3055 Does not wordk. I get the message: scan error 6 switch out/on Actually switching out/on brings no solution
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow ? ! Question/exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
Sep 28, 2011 | Office Equipment & Supplies
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
My gestetner scanner isn't installing on my XP computer. I have an ethernet cable attached, but it doesn't seem to matter when I have the USB 2 attached.
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
Jul 19, 2011 | Computers & Internet
ScanAllPro starts, chose the scanner shows the error: scanner is not connected or another application is using it. but no application is used at this moment. and the test with document scanning by...
Hi,Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.Specify which driver is used for the scanner, the TWAIN or ISIS/VRS driver. When a scanner is no longer connected to a USB port to which it was previously connected, this option checks if any scanner of the same model has been connected to the other USB port. If the same model is found there, this option automatically switches to the other port and inherits the settings of the same model.
* This option will not be available, however, if a different model has been connected to the port where the scanner was previously connected. * Disable the settings when you want to connect more than one scanner of the same model to your computer.
Hope the above information is helpful.
Thanks,
ScanCare
Jun 24, 2011 | Fujitsu fi-5120C
I wanted to print and scanned on canon ir2016i directly from my computer. how can i do that? how can i able the printer identify my IP?
if u are on network then u can simply enter the ip address in system settings tab in additional functions.then load the driver ,it will autorun after detecting machine. the scanner is network scanner and will work only in network.
if u are single pc user then load the drive and connect the machine through usb printer port when the driver asks to connect. hola
May 25, 2011 | Canon iR 2016i Black and White Copier
Hi. I bought an Epson Stylus TX210 printer not to long ago, and it was working fine. Everything except the scanner. so, my parents and I were trying to fix it and I'm not sure what we did wrong because...
im not sure what i'm and doesn't means
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Apr 17, 2011 | Computers & Internet
I can't getting driver of canon 2016j laserprinter
Here's the download page for the iR2016: http://software.canon-europe.com/products/0010245.asp and the iR2016i: http://software.canon-europe.com/products/0010277.asp
(I couldn't find a 2016j)
Hopefully one of those will work for you.
Good luck.
Mar 01, 2011 | Office Equipment & Supplies
How can i reset the linksys ef3116 to default if it doesn not have a reset button or knowing what the ip address is on the switch?
You can use a port scanner to find its IP address, such as Angry IP Scanner http://www.angryip.org/w/Download and reset it from there. It is most likely 192.168.1.x or 10.0.0.x.
Jul 07, 2010 | Linksys EtherFast 3116 Networking Switch
SETUP OF NETWORK PRINTER IR2016I
Install network scan gear on all PCs and make necessary settings ( IP, discover,... ), it should work as PULL scanner.
May 29, 2010 | Canon iR 2016i Black and White Copier
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
315 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
