Question about JVC AV-27D303 27" TV
Tv PROBLEM Hi I have a 27 inch JVC Flat Screen Tube Tv. I turned it on the other day and after being on for about 10 seconds, a black box shows up on the screen, almost like a menu but with no writing. It is It goes away if you hit the volume or change channel, but comes in about 10 seconds. I tried a dvd and the black box shows up too. I tried unplugging it but that didnt work. Any suggestions?
  • tmegronigle Feb 05, 2008
    That did not work. It is a black box that shows up on the screen a few seconds after the channel or volume indicator disappears. I do not have the original remote. how do I reset the tv?
The black box your are seeing on the screen is the box to display text. It is listed under your "cc" closed captioning setting as T1, T2 etc. Go into your closed captioning and shut off the text. You can still leave closed captioning on or off. The text system was never really used but they put it on all of the TV's.
Posted on Nov 29, 2008
Turn off the closed captioning
Posted on Sep 04, 2008
    Champion:
  • 207 Answers
Try check your remote cotrol.maybe, you have accdentally press the menu.. press it again if it works then exit..
if still doesn't work..let me know!!
Posted on Feb 05, 2008
Tv to dark cant see nothing tv's to dim
On the back of the TV, to the right of the I/O panel, there are 2 vertical slot shaped openings on a raised bit of the plastic case. Behind the lower slot is the screen adjuster. Using a phillips screw driver, turn the adjuster clockwise to increase the brightness. Behind the upper slot is the focus adjuster.
Dec 27, 2009 | JVC AV-27D305 27" TV
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
Black screen on EVERY input/channel
Turn off the closed capition
Jun 19, 2009 | JVC AV-27530 27" TV
I have a black retangular box in the middle of the picture screen
i had the same problem with a Sanyo tv, was ready to trash it and a friend told me how to fix it.i went to the tv menu (not cable or satellite menu) and from the settings list chose CLOSED CAPTION . i had inadvertantly made a change there which left me with a black text box and very little viewing area. i just had to make sure all of the options for CC were OFF. hope this helps
May 27, 2009 | JVC AV-27F802 27" TV
JVC TV AV-27230 Black shadow on left of screen
Hiya. Replace C581, 10uf 250V electrolytic capacitor. Common problem on these.
May 26, 2009 | JVC AV-27230 27" TV
Black square appearing on tv
turn off closed captioning
Nov 29, 2008 | JVC AV-27530 27" TV
JVC Screen problem
using your remote ,off the close caption. the black rectangular box that you see for the message but since you have message in the box. that why you see a rectangular black screen.
Jan 09, 2008 | JVC AV-32D305 32" TV
JVC AV 270305 Brightness not Bright enough.
Yes you could look for the capacitor that is leaky, probably in the 200v line, or you could just open back and turn up G2 screen control on the Flyback. You have Screen and Focus on this black transformer with a long anode lead going to the picture tube of set. Becareful, High Voltage!
Sep 08, 2007 | JVC AV-27530 27" TV
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
JVC AV-27D303 27" TV Logo
231 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
