Startup(slow) Hi, ive up graded my Ram to 1GB, giving me a faster computer. The problem being my startup is very sluggish, ive followed procedures to do a disk cleanup and deleted cookies, but this has made no difference to my startup speed, i have heard that the Medion systems are in general very slow to startup. Could you please give me any assistance in getting my bootup to be instantanious. Regards J.Denardo
  • jj27 Feb 14, 2008
    HI,
    everything ive tried isnt making the slightest bit of difference to the start up speed. i have been adviced i need to do a factory reset and delete a load of programs that have come preinstalled with the system, i really dont want to have to do this, as i am not computer illiterate enough. any ideas?
  • 796 Answers
What happened to your problem is it solved????
Posted on Feb 13, 2008
  • isaac johny
    isaac johny Feb 13, 2008
    type "msconfig" in run....
    disselect all the programs in the startup....this will speed up the start-up of your computer...
    Genius:
  • 3,422 Answers
1. Defrag your hard drive. Use the built in XP defragmenter (dfrg.msc). It's the only one that properly optimizes your system's prefetching to speed up boot time.
2. Go to Microsoft's website and download BootVis.exe. It will optimize your prefetching even further than the built in defragmenter. Use both to get the best results: dfrg.msc
first, then BootVis.exe->Tools menu->Optimize. Also, you can use it to benchmark your boot time before and after system tweaks and software installations.
3. Go to Start->Run... and type or paste "Rundll32.exe advapi32.dll,ProcessIdleTasks". This will start a built in optimization routine that runs in the System Idle Process
and shows up as "rundll32.exe" in task manager. It normally runs automatically every 3 days. It will run for 15 mins to half an hour, so don't try to do anything too intensive while its running. If you get sick of it running, you should probably
log off or restart to be safe, rather than killing the process.
4. Delete anything that you don't need in the Start->Programs->Startup folder, and
in the Registry under HKLM->Software->Microsoft->Windows->Run and HKCU->Software->Microsoft->Windows->Run.
5. Go to Start->Control Panel->Administrative Tools->Services or go to Start->Run...
and type "services.msc" to display services running on your machine. About 1/3 should be automatic, 1/3 should be manual, and 1/3 should be disabled, IMHO. If you don't
know which to change, search google for "XP services" and read one of the many webpages that describe each service.
6. Use a partition manager to create a separate partition for your swap-file. Set its size to about 2.5 times the amount of physical RAM you have. You can do this by right-clicking my computer and selecting Properties->Advanced tab->Performance section->Settings button->Advanced tab again->Virtual Memory section->Change button.
Whew! They don't make that one easy to get to. Just don't completely remove your swap file, cause your system might not boot after that, unless you have a lot of physical RAM.
7. Repeat steps 1-3.
Ideally, XP on a clean install should boot in about 12 seconds from the time that you see the XP logo to useable (can open a program). With all my device drivers and third-party utilities, the best I can acheive so far is 18 seconds on my Dell.
Don't use Norton SpeedDisk!--It may slow your XP system boot time by about 6 seconds.Also never use norton antivirus.
you can also have a look at this:
click here
if u have any other problem please do ask me
Good luck,
Please don't forget to rate me as fixya..
Posted on Feb 05, 2008
  • Priya darshan Feb 14, 2008
    The solution which i gave you is the only method to increase the startup speed.Did you try that??If not please do it or i better suggest you to take a backup and then reinstall your operating system for best results if you feel the method is tough.
  • 2,334 Answers
If the startup was sluggish before the upgrade, the memory will only help when the PC is running or you have more windows open at the same time.
I would suggest to get rid off programs you do not use often, put them on a USB disk drive, you can also do a disk defragmentation.
Hope this helps.
    Sergeant:
  • 226 Answers
Pls reply with your computer specs including the ram that you purchased.
first thing to do.
be sure that your ram is seated properly to the slot.
enter the bios to check is your ram is detected bby your system.
then proceed.
be sure that your antivirus is updated.
run a full scan of antivirus to check if you are infected by viruses and other malicious programs.
remove unwanted programs to free up disk space.
  • earl llanera
    earl llanera Feb 05, 2008
    go to my computer
    right click on drive c:
    run disk clean up
  • 871 Answers
Hi there
do the following
start>run>%temp% ... delete all thats in this folder.
start>run>temp ... delete all too.
start>run>type inetcpl.cpl ...delete temp internet files & cookies.
And also have a disk optimization software like tuneup utilities.
defragment your drive too as well as the registry.
Vopt is a great defragmenter. Registry mechanic as well.
hope this helps you.
  • earl norman llanera
    earl norman llanera Feb 05, 2008
    Having a slow system startup only means that your system takes time to load up the software you have installed and that runs during startup. As long as you maintain your system like what i said above, You can also try modifying you startup. heres how.
    start>run>type msconfig
    under the startup tab, uncheck all and restart your pc. this only means that you disabled the softwares that requires to start during startup. If you have antivirus installed, please check that so that you will still have protection for your computer.
    WOW. so many experts :)
    Champion:
  • 207 Answers
Have you checked your RAM on your sytem properties? because in general, it will not to tend to slow..maybe, it didn't detect at all.try reseat your RAM to your motherboard.ok? try also check your video card, make sure it has bigger memory and transfer rate because this is also the main cause to slow the performance of your computer.. check also your operating system (windows XP) that must be updated because this will give the latest drivers of your hardware and software and improves the performance of your computer.
if still sluggish, let me know here!!!
    Guru:
  • 1,894 Answers
Hello
  • 4 more comments
  • dewan nafees ahmed Feb 05, 2008
    what is the operating system you are using?
    assuming its XP..
    go to RUN... type msconfig. press enter.
    now go to last tab of the window named as start up.
    now press disable all. now again boot the syatem and see.
    there are hundreds of reasons why s system will go slow.
    you can try one by one, this is not a big problem.
    hi there i uploaded this file for your refrence,
    there are many ways.
    i can type all those in here. have a look at it.
    http://www.filefactory.com/file/a786d7/
    First of all, this tweak only apply to those who only have one HDD on their primary IDE channel (nothing else on device 0 or 1) and a CD-ROM and/or DVD-ROM on the secondary IDE channel. Each time you boot Windows XP, there's an updated file called NTOSBOOT-*.pf who appears in your prefetch directory (%SystemRoot%Prefetch) and there's no need to erease any other files as the new prefetch option in XP really improves loading time of installed programs. We only want WindowsXP to boot faster and not decrease its performance. Thanks to Rod Cahoon (for the prefetch automation process...with a minor change of mine) and Zeb for the IDE Channel tweak as those two tricks, coupled together with a little modification, result in an EXTREMELY fast bootup:
    1. Open notepad.exe, type "del c:windowsprefetch tosboot-*.* /q" (without the quotes) & save as "ntosboot.bat" in c:
    2. From the Start menu, select "Run..." & type "gpedit.msc".
    3. Double click "Windows Settings" under "Computer Configuration" and double click again on "Shutdown" in the right window.
    4. In the new window, click "add", "Browse", locate your "ntosboot.bat" file & click "Open".
    5. Click "OK", "Apply" & "OK" once again to exit.
    6. From the Start menu, select "Run..." & type "devmgmt.msc".
    7. Double click on "IDE ATA/ATAPI controllers"
    8. Right click on "Primary IDE Channel" and select "Properties".
    9. Select the "Advanced Settings" tab then on the device 0 or 1 that doesn't have 'device type' greyed out select 'none' instead of 'autodetect' & click "OK".
    10. Right click on "Secondary IDE channel", select "Properties" and repeat step 9.
    11. Reboot your computer.
    WindowsXP should now boot REALLY faster.
    it worked for me once. you too can try
  • dewan nafees ahmed Feb 13, 2008
    what happened?
  • dewan nafees ahmed Feb 14, 2008
    no reply from you?
    what happened?
Laptop runs super slow and I just bought it 3 days ago
STEP 1: Make Computer Faster by Upgrading RAM
Step 2: Make Computer Faster by Removing Computer Viruses, malwares
Step 3: Make Computer Faster by fixing registry errors
(Use PC Fresher)
Step 4: Make Computer Faster by Minimizing Startup Programs
Go to Run.
Type msconfig and press Enter.
The General tab helps diagnose if the problems encountered are with drivers, services, or startup items by unchecking the appropriate boxes and restarting. The Startup tab allows you to individual disable or re-enable startup items.
Oct 08, 2013 | Computers & Internet
Why does it take a very long time to open a laptop or file?
If you posted the Acer Model and the OS you are using it would be helpful. If you are referring to a slow Boot and slow running I would start by Cleaning the junk from your machine and disabling startup and running processes. Run a Full scan with your up-to-date Anti Virus. Run a Full Scan with Freeware MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ Uncheck the Trial Pro version, you want the freeware version. Run a FULL Scan, delete ALL results, reboot. Download freeware CCLEANER to clean the junk from your machine, in the TOOLS section, STARTUP section, Disable ALL unnecessary startup programs, reboot. With out knowing your OS I'll give you a Windows 7 procedure to increase speed: http://www.pcmag.com/article2/0,2817,2364937,00.asp This is a start, you can also add more memory, faster HDD, etc. As the computer gets used more and more software and junk is added slowing it down, get rid of the junk and unnecessary startup programs.
Mar 18, 2013 | Acer Computers & Internet
Its verry slow
Step 1: Make Computer Faster by Upgrading RAM
Also try to use computer optimization tool PCFresher to speed up windows.
Feb 18, 2013 | Computers & Internet
Laptop runs slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Feb 17, 2013 | Packard Bell Easy One Silver 2101 Notebook
Is there a way to increase its RAM from 1GB to 2GB? Or, are there other ways to make it run faster?
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Nov 08, 2012 | Fujitsu FMV lifebook TH40/D
My pc speed is too slow. sometime it hag very much .please i request you to give mesome solution
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 07, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
My computer starts at the blue start up screen and it takes it about 10 minutes to load the log in screen. It wasn't doing this at first. I have done multiple system restores, but it hasn't helped....
hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup? My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
Dec 07, 2017 | HEWLETT-PACKARD Black 20" TouchSmart...
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
My pc is very slow what should be done?it is having 1gb ram, dual processor and 180 gb hdd.
do virus scan. Make sure you have only ONE anti virus system on your PC - otherwise it will slow down dramatically
disable startup items.
Go to start->RUN -> type in msconfig press enter
Then go to startup and disable all and test if speed will increase.
If it will get faster - you can enable startups one by one and see which program slowing down your PC
Sep 14, 2009 | Computers & Internet
Computer is TOOOO SLOW
probably due to all of the stuff in your startup folder a new pc comes with. the less stuff in your startup the better. you may need a memory upgrade of 1GB or less. I would go at least to 2GB of RAM
Jan 12, 2009 | IBM ThinkPad T60 Notebook
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
